Kernel panic in nvmap_handle_remove with DeepStream + Argus on Xavier NX (JP 5.1.4)
I’m seeing a reproducible kernel panic on a Jetson Xavier NX with a custom carrier board, running JetPack 5.1.4 (L4T R35.6.0).
Setup:
  • One DeepStream pipeline with nvarguscamerasrc + nvinfer + nvtracker
  • One additional GStreamer pipeline using nvarguscamerasrc
Issue:
After running for a while (anywhere from ~24 minutes to ~29 hours), the system panics. Example trace:
kernel BUG at /usr/src/kernel/nvidia/drivers/video/tegra/nvmap/nvmap_handle.c:106!
Internal error: Oops - BUG: 00000000f2000800 [#1] PREEMPT SMP
CPU: 1 PID: 176857 Comm: argus_thread Tainted: G           OE     5.10.216-tegra #2
nvmap_handle_remove+0xec/0x100 [nvmap]
_nvmap_handle_free+0x9c/0x4a0 [nvmap]
nvmap_handle_put+0x10c/0x1e8 [nvmap]
nvmap_dmabuf_release+0x118/0x150 [nvmap]
Full kernel log captured over the serial debug console during the panics:
270825cap.txt (3.3 MB)
Notes:
  • Periodically restarting the DeepStream pipeline avoids the panic.
  • Nothing unusual is seen in the logs prior to the panic, except soctherm: OC ALARM 0x00000001. The module is powered with a stable 5V supply, drawing at most ~18W.
Questions:
  1. Is this a known issue on Xavier NX / JetPack 5.1.4?
  2. Has it been fixed in newer releases such as JetPack 6.2.1 for Orin NX?
  3. Are there recommended workarounds for 5.1.4 beyond periodically restarting the pipelines?
From description, it looks to be memory leak somewhere. Please help
  1. Share the full gstreamer pipeline
  2. Try nvarguscamerasrc ! fakesink. Would like to confirm whether only nvarguscamerasrc has the issue or not
Hi, thanks for the quick response.
Here is the full pipeline (equivalent to our Python code):
gst-launch-1.0 -e \
  nvarguscamerasrc sensor-id=0 \
    ! 'video/x-raw(memory:NVMM), width=3840, height=2160, framerate=10/1, format=NV12' \
    ! nvvidconv flip-method=2 \
    ! 'video/x-raw(memory:NVMM), width=1280, height=736, format=RGBA' \
    ! mux.sink_0 \
  nvstreammux name=mux width=1280 height=736 batch-size=1 live-source=true \
    ! nvinfer config-file-path=config.txt \
    ! nvtracker ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so \
                ll-config-file=config_tracker.yml display-tracking-id=0 \
    ! tee name=t \
    ! queue max-size-buffers=1 leaky=2 silent=true \
    ! nvmsgconv frame-interval=1 msg2p-newapi=true payload-type=PAYLOAD_DEEPSTREAM_MINIMAL \
                multiple-payloads=1 config=msgconfig.txt \
    ! nvmsgbroker proto-lib=/opt/nvidia/deepstream/deepstream-6.3/lib/libnvds_mqtt_proto.so \
                  topic=detections conn-str="127.0.0.1;1883" \
  t. \
    ! queue max-size-buffers=10 leaky=2 silent=true \
    ! nvdsosd process-mode=1 display-text=0 \
    ! nvvidconv ! 'video/x-raw,width=1280,height=720' \
    ! shmsink socket-path=/tmp/video_out sync=false wait-for-connection=false shm-size=20000000
The second pipeline in our setup is using nvarguscamerasrc, and it can run on its own for days without any issues. Would it help if I try running two parallel nvarguscamerasrc ! fakesink pipelines to see if the issue can be reproduced that way?
In Deepstream you should use nvvideoconvert plugin. Please replace nvvidconv plugin with nvvideoconvert and see if the issue is present.
I replaced both nvvidconv elements with nvvideoconvert and reran the test. The behavior is unchanged, the system still eventually panics with the same BUG.
010925cap.txt (3.4 MB)
gst-launch-1.0 -e \
    ! ! nvvideoconvert \
    ! mux.sink_0 \
    ! tee name=t \
    ! fakesink
  t. \
    ! nvvideoconvert ! 'video/x-raw,width=1280,height=720' \
    ! fakesink
Please try the command and see if the issue is still present. Would like to break down the pipeline by eliminating nvmsgconv, nvmsgbroker, shmsink plugins.
