Kernel panic occurs when deepstream service is configured and executed in systemd
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 8.5.2-1+cuda11.4
• Issue Type( questions, new requirements, bugs) bugs
@prominence_ai
The app I use is a dsl-based Deepstream-app made by him
Let’s take an example situation
When running the app directly after booting up —> Normal operation (Good)
When I try to test the app by rebooting after registering in systemd, it turns off after 3-4 seconds after booting. —> Bad operation (like written /etc/systemd/system/myapp.service)
However, by adding the code below to the first part of my main app to cause delay in the pipeline, the phenomenon disappears.
std::this_thread::sleep_for(std::chrono::milliseconds(5000));
Pipeline play()
Also to note, if I intentionally disconnect the camera for example to prevent the inference from starting, booting is fine. However, if I set it to be inference from bootup, it will be turned off.
Maybe it’s because loading the library took a while…
Do you know anything about it??
The attached log below is the log dumped when the system shuts down after booting, but there seems to be no noteworthy log.
fcam_gst_debug.log (90.3 KB)
Thank you
kernel panic
Do you mean that when deepstream starts using systemd, the system crashes?
Usually the application does not cause the system to crash
It may be caused by some drivers.
I guess it may be related to the camera driver.
Can you share your systemd configure ?
Or
Try start deepstream after system module loaded.
[Unit]
Requires=systemd-modules-load.service
After=systemd-modules-load.service
The same error occurs when the camera is set or video is set as input as well.
It is a dependent part of my service, but there is no doubt about it??
neuboat.service
● ├─-.mount
● ├─system.slice
● ├─network-online.target
● │ └─NetworkManager-wait-online.service
● └─sysinit.target
●   ├─apparmor.service
●   ├─dev-hugepages.mount
●   ├─dev-mqueue.mount
●   ├─keyboard-setup.service
●   ├─kmod-static-nodes.service
●   ├─nv-tee-supplicant.service
●   ├─nvfb-udev.service
●   ├─plymouth-read-write.service
●   ├─plymouth-start.service
●   ├─proc-sys-fs-binfmt_misc.automount
●   ├─resolvconf.service
●   ├─setvtrgb.service
●   ├─sys-fs-fuse-connections.mount
●   ├─sys-kernel-config.mount
●   ├─sys-kernel-debug.mount
●   ├─sys-kernel-tracing.mount
●   ├─systemd-ask-password-console.path
●   ├─systemd-binfmt.service
●   ├─systemd-boot-system-token.service
●   ├─systemd-hwdb-update.service
●   ├─systemd-journal-flush.service
●   ├─systemd-journald.service
●   ├─systemd-machine-id-commit.service
●   ├─systemd-modules-load.service
●   ├─systemd-pstore.service
●   ├─systemd-random-seed.service
●   ├─systemd-sysctl.service
●   ├─systemd-sysusers.service
●   ├─systemd-timesyncd.service
●   ├─systemd-tmpfiles-setup-dev.service
●   ├─systemd-tmpfiles-setup.service
●   ├─systemd-udev-trigger.service
●   ├─systemd-udevd.service
●   ├─systemd-update-utmp.service
●   ├─cryptsetup.target
●   ├─local-fs.target
●   │ ├─-.mount
●   │ ├─systemd-fsck-root.service
●   │ └─systemd-remount-fs.service
●   └─swap.target
try the below command to got failure log.
journalctl -u neuboat.service > log.txt
I need to get the failure logs to know what happened. From your description, I can only guess that some dependencies are not started before your service
The components are built fine, there are no obvious error codes, but the kernel crashes.
root@K236ORUA000005:~# journalctl -u neuboat.service -f
-- Logs begin at Thu 2022-09-08 09:58:15 UTC. --
Jul 25 08:32:05 K236ORUA000005 tcd[2500]:  tile = ../../data/tm/aiboat.db
Jul 25 08:32:05 K236ORUA000005 tcd[2500]: =========================
Jul 25 08:32:05 K236ORUA000005 tcd[2500]: open_tile_db(../../data/tm/aiboat.db) failed. ret=-2
Jul 25 08:32:05 K236ORUA000005 tcd[2562]: === CM-RCS Start... ===
Jul 25 08:32:05 K236ORUA000005 tcd[2562]: === Running Options ===
Jul 25 08:32:05 K236ORUA000005 tcd[2562]:  ini  = ../cfg/cm.ini
Jul 25 08:32:05 K236ORUA000005 tcd[2562]:  acnt = ../cfg/acnt.info
Jul 25 08:32:05 K236ORUA000005 tcd[2562]:  tile = ../data/tilemap.db
Jul 25 08:32:05 K236ORUA000005 tcd[2562]: =========================
Jul 25 08:32:05 K236ORUA000005 tcd[2562]: open_tile_db(../data/tilemap.db) failed. ret=-2
Jul 25 08:32:07 K236ORUA000005 tcd[2867]: modprobe: FATAL: Module nvidia not found in directory /lib/modules/5.10.104-tegra
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: === INFERENCE Start... ===
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: === Running Options ===
Jul 25 08:32:12 K236ORUA000005 tcd[2650]:  ini  = ../cfg/fcam_od.ini
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: =========================
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: [ami_init] g_ami_data.ipstr=192.168.0.200, pCFG->nbnet_ipstr=192.168.0.200
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: <REG-DONE> appid=00001021, pss_id=21
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: Success load INI file
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: rtsp-source component add
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: primary-gie component add
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: tracker component add
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: fake-sink component add
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: Opening in BLOCKING MODE
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: gstnvtracker: Batch processing is ON
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: gstnvtracker: Past frame output is OFF
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: INFO: [Implicit Engine Info]: layers num: 4
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: 0   INPUT  kFLOAT input           3x544x960
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: 1   OUTPUT kFLOAT boxes           32130x4
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: 2   OUTPUT kFLOAT scores          32130x1
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: 3   OUTPUT kFLOAT classes         32130x1
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: previous state = DSL_STATE_NULL, new state = DSL_STATE_READY
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: previous state = DSL_STATE_READY, new state = DSL_STATE_PAUSED
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: previous state = DSL_STATE_PAUSED, new state = DSL_STATE_PLAYING
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: NvMMLiteOpen : Block : BlockType = 277
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: NVMEDIA: Reading vendor.tegra.display-size : status: 6
Jul 25 08:32:12 K236ORUA000005 tcd[2650]: NvMMLiteBlockCreate : Block : BlockType = 277
There is a similar question here
It provides a workaround.
What’s your pipeline ?
Use gst-launch to replace deepstream-app to help find where the problem is.
After checking, in my case… I suspect it’s a hardware issue.
