Kernel Panic on Jetson TX2 Development Board
On flashing the default images(SD card mounting) using L4T Toolchain Flash.sh script. I have not modified anything. Still I’m facing kernel panic. Please find the details below.
EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null) jetson
Welcome to the NVIDIA Developer forums! I’m moving this topic from Tegra Tools to the Jetson TX2 forum for greater visibility.
Maybe you should provide full log, because this log does not look like a kernel panic…
hello user2628,
TX2 DevKits use internal eMMC, are you having SD card and Flashing to an External Storage Device?
