We are using the Jetson xavier with Jetpack 4.6.1
deesptream version : 6.0.1
CUDA version : 10.2
We have written a service file to to start the deepstream sample during startup.
But when starting the service manually using the below command it worked
but if enabled it may cause kernal panic and it is rebooting.
sudo systemctl start deepstream-demo.service
Could you please let me know the root cause of the problem and if there is any option to stop the kernel panic other than reflashing the device.
There is no any log info about DeepStream in your log file. When you use deepstream as system service, you must make sure that it starts last. Deepstream deepends on many other services.
Hi @krishnaprasad.k Can you let us know if the issue is solved or not? Thanks.
