I have been writing a very simple test I2S kernel module for kernel-5.10
where I memory map an I2S base register for the Jetson AGX Xavier I2S module into the kernel address space. I obtained the base register addresses (see i2s_driver_test/i2s.h · master · Peterson Yuhala / jetson-xavier · GitLab) by reading the corresponding device tree file for my device. The code for the simple kernel module in question can be found here:
i2s_driver_test/i2s_driver_test.c · master · Peterson Yuhala / jetson-xavier · GitLab
Once I load the kernel module (using sudo insmod module_name.ko
), my Jetson AGX Xavier kit freezes and reboots. Below is part of the error log obtained after the crash happens:
Ubuntu 20.04.5 LTS jetson-desktop ttyTCU0
jetson-desktop login: [ 1509.076800] CPU:0, Error: cbb-noc@2300000, irq=15
[ 1509.076942] **************************************
[ 1509.077056] CPU:0, Error:cbb-noc
[ 1509.077132] Error Logger : 0
[ 1509.077211] ErrLog0 : 0x80030008
[ 1509.077294] Transaction Type : WR - Write, Incrementing
[ 1509.077424] Error Code : SLV
[ 1509.077494] Error Source : Target
[ 1509.077570] Error Description : Target error detected by CBB slave
[ 1509.077704] AXI2APB_1 bridge error: SFIFONE - Status FIFO Not Empty interrupt
[ 1509.077849] AXI2APB_1 bridge error: SLV - SLVERR interrupt
[ 1509.077981] Packet header Lock : 0
[ 1509.078052] Packet header Len1 : 3
[ 1509.078126] NOC protocol version : version >= 2.7
[ 1509.078223] ErrLog1 : 0x320013
[ 1509.078287] ErrLog2 : 0x0
[ 1509.078343] RouteId : 0x320013
[ 1509.078409] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 1509.078505] Targflow : axis_satellite_grout/T/axis_satellite_grout
[ 1509.078978] TargSubRange : 0
[ 1509.079212] SeqId : 0
[ 1509.079412] ErrLog3 : 0x2901120
[ 1509.079965] ErrLog4 : 0x0
[ 1509.082600] Address accessed : 0x2901120
[ 1509.087062] ErrLog5 : 0x489f851
[ 1509.090120] Non-Modify : 0x1
[ 1509.093788] AXI ID : 0x9
[ 1509.096676] Master ID : CCPLEX
[ 1509.099656] Security Group(GRPSEC): 0x7e
[ 1509.103857] Cache : 0x1 -- Bufferable
[ 1509.108315] Protection : 0x2 -- Unprivileged, Non-Secure, Data Access
[ 1509.115139] FALCONSEC : 0x0
[ 1509.118032] Virtual Queuing Channel(VQC): 0x0
[ 1509.122929] **************************************
[ 1509.127971] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:2057!
[ 1509.134304] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 1509.139815] Modules linked in: i2s_driver_test(OE) fuse(E) lzo_rle(E) lzo_compress(E) zram(E) snd_soc_tegra186_asrc(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_dspk(E) snd_soc_tegra186_arad(E) snd_soc_tegra210_admaif(E) snd_soc_tegra210_dmic(E) snd_soc_tegra210_mvc(E) snd_soc_tegra210_iqc(E) snd_soc_tegra_pcm(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_afc(E) snd_soc_tegra210_mixer(E) snd_soc_tegra210_i2s(E) snd_soc_tegra210_amx(E) snd_soc_tegra210_sfc(E) aes_ce_blk(E) crypto_simd(E) cryptd(E) aes_ce_cipher(E) ghash_ce(E) sha2_ce(E) sha256_arm64(E) sha1_ce(E) snd_soc_spdif_tx(E) snd_soc_tegra_machine_driver(E) input_leds(E) loop(E) snd_hda_codec_hdmi(E) snd_soc_tegra210_adsp(E) snd_hda_tegra(E) ucsi_ccg(E) snd_soc_rt5659(E) snd_hda_codec(E) snd_soc_tegra_utils(E) typec_ucsi(E) snd_soc_simple_card_utils(E) typec(E) max77620_thermal(E) nct1008(E) nvadsp(E) snd_soc_tegra210_ahub(E) snd_soc_rl6231(E) tegra210_adma(E) tegra_bpmp_thermal(E) userspace_alert(E) bluedroid_pm(E) snd_hda_core(E)
[ 1509.140048] ahci(E) libahci(E) libata(E) spi_tegra114(E) binfmt_misc(E) ina3221(E) pwm_fan(E) nvgpu(E) nvmap(E) ip_tables(E) x_tables(E) [last unloaded: i2s_driver_test]
[ 1509.242369] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G OE 5.10.104-tegra #3
[ 1509.250243] Hardware name: Unknown Jetson-AGX/Jetson-AGX, BIOS 2.1-32413640 01/24/2023
[ 1509.258385] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[ 1509.264426] pc : tegra194_cbb_err_isr+0x19c/0x1b0
[ 1509.269146] lr : tegra194_cbb_err_isr+0x11c/0x1b0
[ 1509.273883] sp : ffff800010003df0
[ 1509.277540] x29: ffff800010003df0 x28: 0000000000000001
[ 1509.282793] x27: 0000000000000080 x26: ffffde9fd3533f70
[ 1509.288305] x25: ffffde9fd426ae10 x24: 0000000000000001
[ 1509.293988] x23: ffffde9fd3817000 x22: ffffde9fd3faea00
[ 1509.299500] x21: 000000000000000f x20: 0000000000000005
[ 1509.305014] x19: ffffde9fd3fae9f0 x18: 0000000000000010
[ 1509.310350] x17: 0000000000000000 x16: 0000000000000000
[ 1509.315606] x15: ffffde9fd3b12bf0 x14: ffffffffffffffff
[ 1509.321289] x13: ffff8000900039e7 x12: ffff8000100039ef
[ 1509.326367] x11: 0000000000000038 x10: 0101010101010101
[ 1509.332138] x9 : ffff800010003d00 x8 : 2a2a2a2a2a2a2a2a
[ 1509.337650] x7 : 2a2a2a2a2a2a2a09 x6 : c0000000ffff7fff
[ 1509.342907] x5 : ffff612f3fd1c958 x4 : ffffde9fd3b27968
[ 1509.348587] x3 : 0000000000000001 x2 : ffffde9fd1fce170
[ 1509.353668] x1 : ffffde9fd3b12680 x0 : 0000000100010001
[ 1509.359006] Call trace:
[ 1509.361732] tegra194_cbb_err_isr+0x19c/0x1b0
[ 1509.365749] __handle_irq_event_percpu+0x68/0x2a0
[ 1509.370552] handle_irq_event_percpu+0x40/0xa0
[ 1509.375014] handle_irq_event+0x50/0xf0
[ 1509.378520] handle_fasteoi_irq+0xc0/0x170
[ 1509.382815] generic_handle_irq+0x40/0x60
[ 1509.386828] __handle_domain_irq+0x70/0xd0
[ 1509.391048] efi_header_end+0xb0/0xf0
[ 1509.394527] el1_irq+0xd0/0x180
[ 1509.397505] cpuidle_enter_state+0xb8/0x410
[ 1509.401444] cpuidle_enter+0x40/0x60
[ 1509.405221] call_cpuidle+0x44/0x80
[ 1509.408445] do_idle+0x208/0x270
[ 1509.412114] cpu_startup_entry+0x30/0x70
[ 1509.415882] rest_init+0xdc/0xe8
[ 1509.418872] arch_call_rest_init+0x18/0x20
[ 1509.423057] start_kernel+0x514/0x54c
[ 1509.426388] Code: a9446bf9 a94573fb a8c67bfd d65f03c0 (d4210000)
[ 1509.432616] ---[ end trace 98fda04170279c03 ]---
[ 1509.437576] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[ 1509.445108] SMP: stopping secondary CPUs
[ 1509.448981] Kernel Offset: 0x5e9fc1e10000 from 0xffff800010000000
[ 1509.455077] PHYS_OFFSET: 0xffff9ed940000000
[ 1509.458937] CPU features: 0x8240002,03802a30
[ 1509.463410] Memory Limit: none
[ 1509.466552] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
I would be happy if any one could help pinpoint what causes this.
