Kernel panic while including the gobiserial driver in kernel Image in Xavier NX board
Dear team,
I m trying to include the GobiSerial and GobiNet drivers in kernel version 4.9.201(tegra-l4t-r32.5.1) after booting the kernel image Im facing “kernel-panic - not syncing: Attempted to kill init” error. But if i made it as module in the kernel then its booting without any issue and i can insert the module without any error. Please find the log file from below image
Thanks & Regards
Ganesh.K
I know nothing about this driver, but realize that not all drivers have been coded to work as a module, and also the reverse, not all drivers have been coded to be integrated non-module format. The two are not interchangeable unless someone coded it to be so. Where did you get the driver? Was this from a source code of some outside company? If so, then likely it is only intended as module format.
