I’m trying to run the convolutionSeparable example from the SDK 2.3, and I want to change the KERNEL_RADIUS. The documentation shows results with kernel_radius between 1 and 31, but I can only run it with 8.
I tried to change the value KERNEL_RADIUS in the file convolutionSeparable_common.h to 16 or 32, but after I compile and run, I get the following assertion error:
[codebox]
$ ./convolutionSeparable
3072 x 1536
Allocating and intializing host arrays…
Allocating and initializing CUDA arrays…
Running GPU convolution (10 identical iterations)…
convolutionSeparable: convolutionSeparable.cu:167: void convolutionColumnsGPU(float*, float*, int, int): Assertion `8 * 1 >= 16’ failed.
Aborted
[/codebox]
I tried playing around with some of the other constants, but then the correctness test fails.
Has anyone been able to run this example with different kernel radius? I would appreciate any help.
Thanks,
George
