Kernel request: Turn off CONFIG_PPS_DEBUG
In the kernel tegra_defconfig and in future kernel builds, can you turn off CONFIG_PPS_DEBUG? With it enabled and with a pps source connected, the kernel log fills up with 2 messages every second which is a little annoying.
@gtj
You can make your own customize kernel Image to disable it.
Yes I know and I do. I was suggesting this as a default so others wouldn’t have to recompile the kernel just to turn off the messages.
Thanks for your suggestion.
Will report it as consider list.
