say I want to do a kernel wrapper for cuda kernel
in project.cu file:
#include "project.h"
__global__ void kernel(
extern "C" void kernel_wrapper(
kernel<<<...,...>>>(... ...);
in project.h file:
extern "C" void kernel_wrapper(... ...);
in main.cpp file:
int main(void)
Visual studio 2008 gives following error in release mode.
1>MSVCRT.lib(MSVCR90.dll) : error LNK2005: _malloc already defined in LIBCMT.lib(malloc.obj)
1>MSVCRT.lib(MSVCR90.dll) : error LNK2005: ___iob_func already defined in LIBCMT.lib(_file.obj)
1>MSVCRT.lib(MSVCR90.dll) : error LNK2005: _printf already defined in LIBCMT.lib(printf.obj)
1>MSVCRT.lib(MSVCR90.dll) : error LNK2005: _fprintf already defined in LIBCMT.lib(fprintf.obj)
1>MSVCRT.lib(MSVCR90.dll) : error LNK2005: _exit already defined in LIBCMT.lib(crt0dat.obj
and some of the errors in debug mode:
1>MSVCRTD.lib(MSVCR90D.dll) : error LNK2005: _printf already defined in LIBCMT.lib(printf.obj)
1>MSVCRTD.lib(MSVCR90D.dll) : error LNK2005: _malloc already defined in LIBCMT.lib(malloc.obj)
1>MSVCRTD.lib(MSVCR90D.dll) : error LNK2005: _exit already defined in LIBCMT.lib(crt0dat.obj)
1>MSVCRTD.lib(MSVCR90D.dll) : error LNK2005: ___iob_func already defined in LIBCMT.lib(_file.obj)
1>MSVCRTD.lib(MSVCR90D.dll) : error LNK2005: _fprintf already defined in LIBCMT.lib(fprintf.obj)
1>MSVCRTD.lib(MSVCR90D.dll) : error LNK2005: _free already defined in LIBCMT.lib(free.obj)
1>LINK : warning LNK4098: defaultlib 'MSVCRTD' conflicts with use of other libs; use /NODEFAULTLIB:library
1>updateHost.cu.obj : error LNK2001: unresolved external symbol _cudaGetErrorString@4
1>initGPU.cu.obj : error LNK2019: unresolved external symbol _cudaGetErrorString@4 referenced in function "int __cdecl cutGetMaxGflopsDeviceId(void)" (?cutGetMaxGflopsDeviceId@@YAHXZ)
1>shutDownGPU.cu.obj : error LNK2001: unresolved external symbol _cudaGetErrorString@4
It seems I have some runtime library linking problems, anyone knows how to resolve this. Thanks.
in project.cu file:
in project.h file:
in main.cpp file:
int main(void)
Hi, It looks like you are trying to mix MS runtime libraries for the two source files (main.cpp, project.cu). Check how you compile all your source. Choose /MT or /MD, but not both, for all compilations. An alternative–not as nice–is to merge project.cu and main.cpp into one file. --Ken
