After porting/building my codebase on the Jetson TX-1 (running linux tegra v3.10.697)
I’m seeing multiple cuda launch failures.
Using cuda-gdb I see the following backtrace:
#0 0x0023a2a0 in cudart::configData::addArgument(void const*, unsigned int, unsigned int) ()
#1 0x002253ec in cudart::cudaApiSetupArgument(void const*, unsigned int, unsigned int) ()
#2 0x0024f1a0 in cudaSetupArgument ()
#3 0x001e81f8 in __device_stub__Z20ivgpu_threshold_grayPK6uchar4PS_jj (__par0=0xe982a600, __par1=0xe9838800, __par2=14400, __par3=1)
at /tmp/tmpxft_0000594c_00000000-4_ivgpu_Utility.cudafe1.stub.c:1
I’m also seeing “CUDA_EXCEPTION_4, Warp Illegal Instruction” when calling a different
function with debugging enabled.
All of this code runs fine on other platforms, Quadro, Telsa etc.
Any help would be greatly appreciated!
