Dear ncu users,
I’m trying to profile a kernel using ncu version 2021.1.0.0:
srun ncu -o profile -f --target-processes all --kernel-name-base=function --kernel-regex axhelm_omp --launch-count 1 “./nek5000”
having the following error:
==ERROR== Failed to profile kernel “nvkernel_axhelm_omp__F1L608_1_” in process 21044
Fatal error: expression ‘HX_CU_CALL_CHECK(p_cuStreamSynchronize(stream[dev]))’ (value 1) is not equal to expression ‘HX_SUCCESS’ (value 0)
==PROF== Profiling “nvkernel_axhelm_omp__F1L608_1_”: 0%
==WARNING== Backing up device memory in system memory. Kernel replay might be slow. Consider using application replay to avoid memory save-and-restore.
==ERROR== The application returned an error code (6).
==ERROR== An error occurred while trying to profile.
==WARNING== No kernels were profiled.
…50%…100% - 11 passes
==PROF== Profiling “nvkernel_axhelm_omp__F1L608_1_”: 0%==PROF== Received signal
==PROF== Trying to shutdown target application
==PROF== Profiling “nvkernel_axhelm_omp__F1L608_1_”: ==PROF== Received signal
The application works well with nsys and without profiling. What is the problem with such kernel? Thanks.
