I have used Jetpack v3.3 to flash my TX2 since I need to use CUDA 9. However, after installation, the keyboard and mouse are not working. Following is the output of dmesg.
[ 18.774254] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 18.774263] xhci-tegra 3530000.xhci: Falling back to user helper
[ 18.775868] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 19.774223] xhci-tegra 3530000.xhci: Leaving it upto user to load firmware!
[ 19.781214] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 19.781219] xhci-tegra 3530000.xhci: Falling back to user helper
[ 24.174243] tegradc 15210000.nvdisplay: unblank
[ 24.211145] tegradc 15210000.nvdisplay: blank - normal
[ 25.301143] tegradc 15210000.nvdisplay: unblank
[ 27.124512] IPVS: Creating netns size=1424 id=2
[ 325.941161] tegradc 15210000.nvdisplay: unblank
[ 325.941176] tegradc 15210000.nvdisplay: blank - normal
[ 325.951994] tegradc 15210000.nvdisplay: blank - powerdown
I connected with ssh and tried to debug and I get following error message,
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
How can I fix it?
