I attempted to execute a cmake build and rebooted, but I still encountered an infinite login loop.
To resolve this, I reinstalled the display manager and chose gdm3.
However, this time the keyboard and mouse input were not working.
I attempted to access the tty terminal, but I couldn’t because the keyboard is not working
Incidentally, the micro-OTG USB connector to the left of the 40-pin header on the AGX Xavier dev kit is the serial console for that model. You’d just plug in the micro-B USB to that connector, watch “dmesg --follow” on the Linux host PC, and plug in the USB-A side to the host PC (the log message should show the names of the serial devices). The first serial device is named when running a serial console program on the host PC with speed 115200, 8 bits, no parity, and one stop bit.
Thank you for the additional information! On Windows, I opened a total of four ports by connecting via micro-USB ctype for serial connection. I tried opening the serial console with the settings you mentioned, but there was no response. Does it not work on Windows?
I don’t now if it is COM5 or something else. Serial console does work from Windows, but finding the right setup might be a bit more frustrating. You might try with all of the COM ports.
