I’m using Ubuntu 22.04 on a Jetson Orin AGX. Ubuntu has always booted up normally on my jetson and I’ve been using it successfully since I originally installed Ubuntu 22.04 on the jetson a few months back.
However, today as new Ubuntu updates were being installed on boot, I lost power to my Jetson and, as a result, the updates were interrupted. Now when I try to boot up my Jetson, it immediately boots into emergency mode.
Once it enters emergency mode, this is the final output:
You are in emergency mode. After logging in, type “journalctl -xb” to view system logs, “systemctl reboot” to reboot, “systemctl default” or “exit” to boot into default mode. Press ENTER for maintenance (or press Control-D to continue): _
I’m attempting to type my password to continue when I arrive at the prompt above, but it seems like my keyboard is disabled. Nothing appears when I’m typing my password (assuming this is because of password security). However, I have numbers and capital letters in my password and if I attempt to turn on Num Lock or Caps Lock on my keyboard, the Num Lock and Caps Lock lights don’t appear on the keyboard. So I’m not sure if the entire keyboard is disabled in emergency mode?
When pressing the Num Lock and Caps Lock keys on the keyboard BEFORE the jetson goes into emergency mode, the Num Lock and Caps Lock lights on the keyboard turn on–so I’m assuming the issue isn’t with my keyboard. Also, if I press ESC on the initial UEFI Boot Configuration screen, I can access the Boot Manager and use the arrow keys successfully on my keyboard. Again, this is BEFORE the jetson goes into emergency mode, so again I’m assuming the issue isn’t with the keyboard.
The jetson uses the UEFI Boot Configuration, so I’m unable to go into a GRUB menu.
And I know there have been previous posts about the keyboard being disabled in emergency mode, but I haven’t found any posts that specifically address this issue where a user is unable to debug from the GRUB menu as in my case here.
I’ve also created a video here that shows the boot process with the keyboard issue. As you can see in the video, the Caps Lock light on the right of my keyboard goes on when I press that key before the jetson goes into emergency mode. But immediately on going into emergency mode, the Caps Lock light will not turn on when pressing the Caps Lock key.
If anyone has any suggestions, it’d be much appreciated!
