sometimes my keyboard stopping responding for almost one minutes. and this phenomenon may happen twice one hour. but at that moment my mouse is ok. I tested both Wired keyboard and wireless keyboard.
Dose some one else have similar issue?
Please provide the kernel message when the issue occurred.
Also some questions to confirm:
- Is your device a dev kit or a custom carrier board?
Thank you for your reply!
I’m using dev kit, this issue happen frequently if I was using Bluetooth. how to collect the kernel message ? at that moment I cannot use keyboard.
Please try to use the serial console to interact between your host and the target device.
You could try to use minicom to access the device and run sudo dmesg commands to check the kernel message.
understood, I will try when this issue happen again. but I usually only have this Ori agx powered on.
I think I also can collect the kernel message after keyboard recovered, right?
Yes.
keyboard_issue.txt (76.4 KB)
Here is the outputs of sudo dmesg commands. just after keyboard recovered.
Thank you!
The dmesg log seems normal.
Could you try connect your keyboard to other device to check whether the issue exists?
yes, I tried on another orin agx before, same issue. with the same software environment.
[quote=“kayccc, post:11, topic:334723”]
s this still an issue to support? Any result can be shared
[/quote] yes, this issue still not solved. but I think it’s hard to find the root cause. I only need to be patient (take a break). and I don’t want to waste your time for this small issue.
