Kimi K3 and the Ceiling of GB10 Clusters
Kimi K3 just came out at 2.8T params, and the benchmarks put it squarely ahead of Opus 4.8 and into 5.6 Sol / Fable 5 territory. Minimax M3 Pro is rumored to be 2.5T param. It seems the new open-source frontier is settling around 2–3T.
With GB10s, at ~115 GB usable per node, you’d need 16 nodes to run K3 at 4-bit. The good news is the active param count seems to only be ~50B, so a 16-node cluster should push ~35–50 tok/s decode. But that setup costs ~$100k and pulls 2,000–3,200W under inference. Out of prosumer reach.
Which means the practical ceiling of a sane GB10 cluster, imo, four nodes, is around Opus-class. Not the frontier. Unless you want to go on adventuring in 2bit/1bit quants or 50% REAPs. I personally will pass on those.
Zhipu’s Fable-equivalent will probably not help. GLM 5 is ~750B against Kimi K2’s 1.6T. If that ratio carries over to the next generation of models (no guarantee), Zhipu’s Fable lands around 1–1.5T, still an 8-node model.
All of this is to say that when you see people on social media shilling Sparks, Mac Studios, and Strix Halos on the promise that models will just keep getting smaller and more capable, maybe. It could happen. But the current trend points the other way, and it’s a bad bet to drop tens of thousands on compute chasing hopes and dreams. Make your purchasing decisions on the current capabilities of the hardware. You will always be able to run GLM 5.2, but don’t make plans for DSV5 in 2027.
P.S. If you reply with something something Qwen I’ll call a wellness check on you :)
I’d temper this by saying that while the overall parameter count is rising, the capability of smaller models in the 30-200B class is also rapidly getting better.
I think the frontier scales easiest with parameters but then distills down with the result being progressively more capable smaller models. Pragmatically, I do not believe we have saturated the 1T class yet never mind closer to 3T. Some in the big labs believe they have to scale big to generate the data/reasoning traces needed to optimize at medium size.
Moreover, even the big players need this to be true, so they can keep hosting/serving the models…
I hope 5 sparks is the long term baseline. It is the largest you could do full mesh without a switch and the associated latency penalty. Also it gives you 640GB of RAM for models like GLM-5.2 with a healthy KV cache.
Flash versions of even 2.5T models should fit in that. Now if there is any interest to release such models only time will tell.
it’s not a gurantee that smaller models can continue to advance. And also a very real possibility that the release of said smaller models will slow down or stop in the future. GLM hasn’t released an Air or Flash in a long while, why would they when they are charging 1200 a year for subs. Minimax M3 has doubled its params, and is 10x their param count with their Pro models. No 124b for Gemma 4. No GPT-OSS2. Qwen is basically a meme now and it’s unknown if we would get another small model anytime soon. DSV4 Flash GA is probably the best bet.
Over just half a year, we’ve gone from “everyone has something that runs on GB10s” to “Everyone is moving away from the 200b class.” This could very well be noise, but it’s just not wise to tell people or yourself to base your significant purchasing decisions on guesses.
How can you do a 5 node without a switch? Is this proven or theoretical?
I hope Zhipu release a 5.5 or 5.7 before moving on to their Fable equivilent… It could be a forever model for me if it has the full capability of Opus 4.8.
I’m confident they can for a while yet. Simply based on information density and ability to compress.
The bellwether is ability to compress. Once we start to truly optimize small models, 4 bit quants will not work anymore. We’ll be back to FP8 minimum. Later, even FP8 will be measurably lossy.
A couple months ago I would have said that Qwen3.6-27B might be an exception, but along comes the prism binary/ternary quants showing us just how much remains on the table.
Also, I’m in good company here - Elon agrees. But we could be wrong. We’ll see.
agree.
It seems every capable big AI labs are rushing to achieve AGI after Mythos impact. Minimax CEO declared no salary for himself until AGI, Deepseek founder 1st time large external investment to go over 1T model.
Unless DSV4 GA Flash, there is less sign of 120B~ 300B range models news. maybe Sol - Luna kinda set might be possible for cost effective serving if they aim 1T ~ 3T models but having extra capability. Hope they do have.
But local llm needs more like ‘good enough’ although expections & task challenges varies. Hopefully we can get 5.6 Sol level under 4 nodes within a year.
edit : DSV5 to DSV4
I’m currently working on making my 4 nodes switch less. The trick is to break down the physical ports that currently are running 4x50GB into sub-ports that are 2x50GB each using MST. Then it’s just a case of sorting out the cabling.
After splitting one of my ports in two I now have six RoCE interfaces instead of the usual four which is what you need for 4 nodes, for 5 nodes you need to split the other port as well.
I don’t know when/if the required DAC cables will be commercially available so I may simply go down the transceiver route and optical breakout cables short term.
We have different definitions for good companies…
Then it’s a lateral move at best. 4bit to FP8 is 2x the size. Currently, the 27B and 12B models differ significantly in their capabilities, and we’ve already condensed a lot.
Binary/ternary quants are amazing. But it’s one thing that they infer, another thing that they can call tools reliably, another thing that companies will have the incentives to retrain their models with PrismML’s techniques, another thing that it works well on trillion-parameter-class models, and yet another thing that SM121 will have the support to run it well anytime soon…
We may or may not be wrong on this, but even if you’re right, it’s still up to the companies to train and release them open source. It’s all the more reason to be cautious and not bank tens/hundreds of thousands of dollars worth of equipments on it.
How much does that cost, in cabling alone? Of course you’re accepting half the bandwidth in exchange for optimal latency.
The Mikrotik CRS804-DDQ is generally thought to be the best in terms of price for perf, but it’s interesting to consider a switch-less alternative.
Alternatives to aforementioned DS4-Flash which are viable in this general size range:
  • Step-3.7-Flash
  • Command-A-Plus
  • Inkling-Small (forthcoming)
  • Laguna-M.1
  • Qwen3.5-397B-A17B
  • Hy3 (a bit bigger, granted)
Also worth noting that several of these have inefficient KV cache and subsequent generations will improve that.
Wild card for some groups like Z-AI which may join the Flash/Air model party.
It’s taken me 6 months of development and a second spark to arrive at a point where I’m producing economically meaningful work with local models. That being said, if nothing gets better and I’m stuck with Mimo-v2.5 for the rest of time locally, I’m still able to produce meaningful work and justify my investment. Better models would be great locally but the need for local is data privacy for me in my work products not in designing or building my workflows. Frontier cloud models to build/code the workflows and optimize them for the local model has been the answer for me and advances in the Frontier (yay Fable) have made my local hardware investment pay off. I imagine the future looks like more of the same. Trickle down computing if you will. It’s likely going to be very community driven for us as it has been thus far with you geniuses coming up with solutions and sharing them.
For 4 nodes you need 2 regular QSFP56 DAC cables, then 4x $150 transceivers and about $200 in optical splitter cables. So around $800 for the optical part. If the 4 transceivers plus optical cables can be replaced with a 4 headed DAC it might be $200 or so.
Now to go from 4 nodes to 5 nodes you will need another 6 transceivers and $300 in optical cabling. If we see 3-headed DACs, well a lot cheaper.
So yes, all in all a MikroTik plus DAC cables will be cheaper than a transceiver based full mesh, a DAC based full mesh would be cheaper than a MikroTik for 5 nodes.
My drive for doing this is to see what impact the reduced latency will have and I really don’t want a noisy switch in my office.
We gotta be open minded @CosmicRaisins there will be ways to compress these models even more by 2027 look at all the optimization and things that have happened these past few months alone I wouldn’t been surprised if we can run DSV5 in some variant come 2027
You can look at the research and weights for the past few months, but you also need to look at the business decisions of the labs for the past few months, and the trend there isn’t great. It is possible that newer labs could become more competitive and release more medium sized models when frontier OSS labs move onto trillions, but I wouldn’t bank on it any time soon.
I’m being very open-minded. There is more optimization and compression headroom. On the other hand, the apparent trend is that for labs that are competitive, development for smaller models is being phased out in favor of larger models and frontier capabilities. It’s perfectly fine to be optimistic about the technology. I am, or I wouldn’t have spent 20k on a cluster. I hate to harp on this, but it’s a-whole-nother thing to FOMO into tens of thousands of dollars of hardware because you might be able to achieve a target performance in 2027.
I guess “it depends” just like everything else in life. If you have a meaningful (to you) use case for local AI, buy/build what you need/can afford now. If you can’t make the hardware useful for yourself now, then I agree, don’t throw a bunch of money at a MAYBE that local AI gets good enough fast enough to do the work you need it to. And, if you’re so upset with your sparks that you just can’t stand the sight of them and need a friend to take them out of your presence, DM me!
External Image
Yes! That’s exactly what I’m saying.
@CosmicRaisins I hear that, but I also think it’s a little too early to bemoan the open-source labs for pushing into the data-center/infrastructure space more than consumer/prosumer right now. That work is more viable for them and I think will pay dividends for us little guys no matter what, even if it is just cheaper frontier level intelligence to build what we need for local hardware. At the end of the day model weights are just numbers and code, how long before you can just ask a frontier model to create optimized weights for your hardware, pretty sure that’s what’s next for local AI.
I just really hope that the amazing opensource community will keep up with optimizations and tooling to perform them. Hell perhaps even new inference engines. The big players are just doing whatever they can to justify the current memory/storage shortage. Let’s brute force new models under the marketing veil of AGI coming (good luck doing that with LLMs, oh by the way give us all your data m’kay). It’s like most other software nowadays. We don’t want to optimize, got to beat the competition in the current boom and craze, up to “you now need a minimum of 1TB HBM4 to be a hobbyist” ho ho ho ho.
I love the capabilities the spark gives me (privacy is the biggest one), but is also a ground to learn, experiment, perhaps even break things. Yes I am a bit worried when it will become redundant and how much the new generation will cost (double with 192G RAM???). I am already itching for a second device but have to be responsible with the money at the moment.
Somehow it feels like having an oldschool computer with a tape drive again (download model, load it into memory…, go grab a cup of coffee or two). Hobbyists chipping with the most innovative ways to use it. Tight-knit community of experts… I really hope we will let to see a bit more efficiency as the time goes.
I hope this mirrors the other bubbles in history (no reason to think it won’t) and the ass falls out of the data center market in the short term, and we can all buy up the hardware at fire sale prices. I’d love to put a couple GB300 racks in my basement, pipe the waste heat into the hot water heater, have an agent fire up some batched jobs whenever you need to take a bath!
