KIND and Interface Block
I’m Trying to create an interface block for coupling a F90 code to a c subroutine library- we had been doing it with inline compiler directives at the location of the call, but I am trying to move it to an interface block in a module, that I would then USE…
      MODULE CInterface
      INTEGER, parameter :: ki4   = SELECTED_INT_KIND(9)
      INTEGER, parameter :: kindr = SELECTED_REAL_KIND(12)
     INTERFACE
         SUBROUTINE xginst(text,sz,length,x1,y1)
            INTEGER(KIND=ki4):: sz,length
            CHARACTER(LEN=*) :: text
            REAL(kindr) :: x1,y1
            !DEC$ ATTRIBUTES STDCALL :: xginst
            !DEC$ ATTRIBUTES REFERENCE :: xginst
         END SUBROUTINE xginst
       END INTERFACE
      END MODULE CInterface
The problem is that it is not allowing parameters in the interface block, and I believe that not all of the compilers we use support the same integer values for sizes-
error S0087 : Non-constant expression where constant expression required
error S0081 : Illegal selector - KIND parameter has unknown value for data type
Does anyone know of a method that works to use parametric KINDs in an Interface Block?
-Russ Johns
Hi Russ,
This is a scoping issue. Meaning that the module’s parameters can not be seen within the interface. So you’ll either need to add the declaration of ki4 and kindr to each subroutine or better yet, put ki4 and kindr in their own module. For example:
      MODULE mykinds
      end module mykinds
      MODULE CInterface
      INTERFACE
            use mykinds
       END INTERFACE
Hope this helps,
Mat
