Hi I want to know if a Kingston NV3 1TB SSD SNV3S/1000G is compatible with Orin Nano 8GB module?
I have seen other posts as well regarding ssd and orin nano but could not find anything regarding NV3. I would really appreciate if I can get an answer for this one :) have a great weekend.
We’re not able to verify to know whther it’s compatible, however some customers have used Kingston SSD NV1-E 500GB M.2 2280 NVMe PCIe 3.0×4 SNVSE/500G without problem, you may compact the HW spec to see if they’re the same.
Hi Thank you for reply, hardware wise they both are similar NV2 and NV3 (I found some reddit post about someone using kingston NV2 with Orin nano). It does seem that it would work. Thank you once again.
