Hi devs,
It would be great if the Omniverse Kit Remote Client allowed the possibility to redefine (loading a configuration file, etc.) the mapping of the ports (with a syntax similar to docker, for example) to connect and work with multiples contained applications running in the same remote workstation.
It is possible only view one container according to the default ports, at the moment: -p 47995-48012:47995-48012/udp -p 47995-48012:47995-48012/tcp -p 49000-49007:49000-49007/tcp -p 49000-49007:49000-49007/udp
