when i use kmeans.py attached in examples/yolo inside docker to generate those shapes, I met error.
Please paste your full command and log.
Copyright © 2019, NVIDIA CORPORATION. All rights reserved.
“”“Kmeans algorithm to select Anchor shape.”""
from future import absolute_import
from future import division
from future import print_function
import argparse
import os
import numpy as np
def parse_args():
Parse command-line flags passed to the training script.
Returns:
Namespace with all parsed arguments.
parser = argparse.ArgumentParser(prog='kmeans', description='Kmeans to select anchors.')
parser.add_argument(
'-l',
'--label_folders',
type=str,
required=True,
nargs='+',
dest='/nfs/volume-709-1/new/tlt-experiments/data/training/label_2',
help='Paths to label files')
'-n',
'--num_clusters',
type=int,
default=9,
help='Number of clusters needed.'
'--ratio_x',
type=float,
default=1.0,
help='x = ratio_x * kitti_x.'
'--ratio_y',
type=float,
default=1.0,
help='y = ratio_y * kitti_y.'
'--max_steps',
type=int,
default=10000,
'--min_x',
type=float,
default=10,
help='ignore boxes with width (as in label) not larger than this value.'
'--min_y',
type=float,
default=10,
help='ignore boxes with height (as in label) not larger than this value.'
return parser.parse_args()
def read_boxes(folders, ratio_x, ratio_y, min_x, min_y):
Read all boxes as two numpy arrays.
Args:
folders (list of strings): paths to kitti label txts.
Returns:
w (1-d array): widths of all boxes
h (1-d array): heights of all boxes
w = []
h = []
for folder in folders:
for txt in os.listdir(folder):
_, ext = os.path.splitext(txt)
if ext != '.txt':
continue
lines = open(os.path.join(folder, txt), 'r').read().split('\n')
for l in lines:
l_sp = l.strip().split()
if len(l_sp) < 15:
continue
left = float(l_sp[4])
top = float(l_sp[5])
right = float(l_sp[6])
bottom = float(l_sp[7])
l_w = right - left
l_h = bottom - top
if l_w > min_x and l_h > min_y:
w.append(l_w * ratio_x)
h.append(l_h * ratio_y)
return np.array(w), np.array(h)
def iou(w0, h0, w1, h1):
Pairwise IOU.
Args:
w0, h0: Boxes group 0
w1, h1: Boxes group 1
Returns:
iou (len(w0) rows and len(w1) cols): pairwise iou scores
len0 = len(w0)
len1 = len(w1)
w0_m = w0.repeat(len1).reshape(len0, len1)
h0_m = h0.repeat(len1).reshape(len0, len1)
w1_m = np.tile(w1, len0).reshape(len0, len1)
h1_m = np.tile(h1, len0).reshape(len0, len1)
area0_m = w0_m * h0_m
area1_m = w1_m * h1_m
area_int_m = np.minimum(w0_m, w1_m) * np.minimum(h0_m, h1_m)
return area_int_m / (area0_m + area1_m - area_int_m)
def kmeans(w, h, num_clusters, max_steps=1000):
Calculate cluster centers.
Args:
w (1-d numpy array): widths
h (1-d numpy array): heights
num_clusters (int): num clusters needed
Returns:
cluster_centers (list of tuples): [(c_w, c_h)] sorted by area
assert len(w) == len(h), "w and h should have same shape"
assert num_clusters < len(w), "Must have more boxes than clusters"
n_box = len(w)
rand_id = np.random.choice(n_box, num_clusters, replace=False)
clusters_w = w[rand_id]
clusters_h = h[rand_id]
# EM-algorithm
cluster_assign = np.zeros((n_box,), int)
for i in range(max_steps):
# shape (n_box, num_cluster)
if i % 10 == 0:
print("Start optimization iteration:", i + 1)
box_cluster_iou = iou(w, h, clusters_w, clusters_h)
re_assign = np.argmax(box_cluster_iou, axis=1)
if all(re_assign == cluster_assign):
# converge
break
cluster_assign = re_assign
for j in range(num_clusters):
clusters_w[j] = np.median(w[cluster_assign == j])
clusters_h[j] = np.median(h[cluster_assign == j])
return sorted(zip(clusters_w, clusters_h), key=lambda x: x[0] * x[1])
def main():
‘’‘Main function.’’’
args = parse_args()
w, h = read_boxes(args.label_folders, args.ratio_x, args.ratio_y, args.min_x, args.min_y)
results = kmeans(w, h, args.num_clusters, args.max_steps)
print('Please use following anchor sizes in YOLO config:')
for x in results:
print("(%0.2f, %0.2f)" % x)
if name == “main”:
main()
I mean, please paste your full log when you run into error.
Sorry, I still cannot understand your attachments.
From jupyter notebook, there is
If you use your own dataset, you will need to run the code below to generate the best anchor shape
!python kmeans.py -l $DATA_DOWNLOAD_DIR/training/label_2
-n 9
–ratio_x 1.0
–ratio_y 1.0The anchor shape generated by this script is sorted. Write the first 3 into small_anchor_shape in the config
file. Write middle 3 into mid_anchor_shape. Write last 3 into big_anchor_shape.
Can you paste the full log when you run above?
Its ok, But I resized the picture, should ratio_x and ratio_y be adjusted? I resized the picture from 1920, 1080 to 1920, 1088.
It can be adjusted. You can find more details in examples/yolo/kmeans.py
