nvidia-bug-report.log.gz (106.9 KB)
After running sudo dnf install akmod-nvidia and not seeing the module show up in modinfo -F version nvidia after over an hour, I figured out how to run sudo akmods directly to look at the build output. That led me to a log file at /var/cache/akmods/nvidia/595.71.05-1-for-7.0.8-200.fc44.x86_64.failed.log
2026/05/17 20:17:32 akmods: Building RPM using the command '/usr/sbin/akmodsbuild --kernels 7.0.8-200.fc44.x86_64 /usr/src/akmods/nvidia-kmod.latest'
Building target platforms: x86_64
Building for target x86_64
Installing /usr/src/akmods/nvidia-kmod.latest
setting SOURCE_DATE_EPOCH=1777334400
Executing(%mkbuilddir): /bin/sh -e /var/tmp/rpm-tmp.whJrHr
Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.h8X5S3
+ umask 022
+ cd /tmp/akmodsbuild.j8a1JGrH//BUILD/nvidia-kmod-595.71.05-build
+ kmodtool --target x86_64 --repo rpmfusion --kmodname nvidia-kmod --filterfile /tmp/akmodsbuild.j8a1JGrH/SOURCES/nvidia-kmodtool-excludekernel-filterfile --obsolete-name nvidia-newest --obsolete-version 3:595.71.05-1.fc44 --akmod --for-kernels 7.0.8-200.fc44.x86_64
error: Bad exit status from /var/tmp/rpm-tmp.h8X5S3 (%prep)
RPM build errors:
2026/05/17 20:17:32 akmodsbuild: * Rebuilding /usr/src/akmods/nvidia-kmod.latest for kernel(s) 7.0.8-200.fc44.x86_64: Building target platforms: x86_64
2026/05/17 20:17:32 akmodsbuild: Building for target x86_64
2026/05/17 20:17:32 akmodsbuild: Installing /usr/src/akmods/nvidia-kmod.latest
2026/05/17 20:17:32 akmodsbuild: setting SOURCE_DATE_EPOCH=1777334400
2026/05/17 20:17:32 akmodsbuild: Executing(%mkbuilddir): /bin/sh -e /var/tmp/rpm-tmp.whJrHr
2026/05/17 20:17:32 akmodsbuild: Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.h8X5S3
2026/05/17 20:17:32 akmodsbuild: + umask 022
2026/05/17 20:17:32 akmodsbuild: + cd /tmp/akmodsbuild.j8a1JGrH//BUILD/nvidia-kmod-595.71.05-build
2026/05/17 20:17:32 akmodsbuild: + kmodtool --target x86_64 --repo rpmfusion --kmodname nvidia-kmod --filterfile /tmp/akmodsbuild.j8a1JGrH/SOURCES/nvidia-kmodtool-excludekernel-filterfile --obsolete-name nvidia-newest --obsolete-version 3:595.71.05-1.fc44 --akmod --for-kernels 7.0.8-200.fc44.x86_64
2026/05/17 20:17:32 akmodsbuild: error: Bad exit status from /var/tmp/rpm-tmp.h8X5S3 (%prep)
2026/05/17 20:17:32 akmodsbuild: RPM build errors:
2026/05/17 20:17:32 akmodsbuild: Bad exit status from /var/tmp/rpm-tmp.h8X5S3 (%prep)
2026/05/17 20:17:37 akmods: Building rpms failed; see /var/cache/akmods/nvidia/595.71.05-1-for-7.0.8-200.fc44.x86_64.failed.log for details
There doesn’t seem to be any useful info here on what went wrong, just two “Bad exit status” messages.
This is a fresh install of Fedora 44, from earlier today. GPU is an RTX 3070 Ti.
