Hello everyone,
I’d like to share an experimental project called Knema and open it up for technical discussion and feedback.
Knema is not an FPS booster, not an upscaler, and not a rendering feature.
Its focus is frametime continuity and stability improving perceived smoothness by managing how frames arrive, not by chasing higher benchmark numbers.
Philosophy
Most performance tools aim to maximize FPS. Knema takes a different approach:
Prioritizes frametime shape and consistency over peak FPS
Treats sudden spikes, oscillations, and pacing instability as first-class problems
Makes decisions based on real hardware limits, not ideal targets
Avoids aggressive boosting when the GPU is already at its physical ceiling
In short:
Stable, predictable frames are often more important than higher FPS.
What Knema Does
Monitors frametime distribution (mean, p95, jitter)
Detects GPU-bound vs engine-wait vs telemetry anomalies
Applies adaptive FPS and power behavior only when it improves continuity
Backs off automatically when limits are reached instead of forcing corrections
Handles common issues such as focus changes, telemetry gaps, and false utilization drops
Current State
Tested on multiple NVIDIA GPUs and several real-world gaming scenarios
Early results show reduced micro-stutter and more consistent frame pacing
However, testing is not exhaustive, and behavior may vary by system, driver, or game
Important Disclaimer
Knema is experimental software.
Not all edge cases have been tested
No guarantees are made regarding stability, performance gains, or compatibility
Use is entirely at your own risk
The author assumes no responsibility for crashes, data loss, hardware issues, or unintended side effects
If you choose to try it, please do so with caution and avoid critical or sensitive environments.
Download
Knema is available here:
https://sourceforge.net/projects/knema/
Feedback, criticism, and technical discussion are welcome.
I’m especially interested in perspectives on frametime analysis, pacing strategies, and GPU-bound decision logic.
Thanks for reading.
