With the Clara Holoscan SDK v0.2 release, there are a few known issues
[3655489] Installing dGPU drivers can remove nvgpuswitch.py script from the executable
search path. Explicitly including /opt/nvidia/l4t-gputools/bin in the PATH
environment variable ensures this script can be found for execution.
[3599303] Linux kernel is not built with security hardening flags. Future releases will
include a Linux kernel built with security hardening flags.
[3633688] RDMA on the Clara Holoscan Developer Kit is not functional. This will be fixed
in future PCIe switch firmware updates. RDMA for the Clara AGX
Development Kit is functional and unaffected by this issue.
[3671100] Configuring the PCIe BAR size on the Clara Holoscan Devkit to 8GB can
cause the NVIDIA device driver to fail to load. Setting to the default BAR size
of 256MB allows the device drivers to load. Future software updates may
enable larger BAR sizes.
[3675821] The largest resolution of HDMI-CSI input is restricted to 2K in iGPU mode and
new UEFI firmware does not autodetect the HDMI-CSI converter. 4K may be
supported in future software updates, and manual detection of the converter
can be forced by executing the /opt/nvidia/jetson-io/jetson-io.py tool to
configure the CSI Connector / HDMI CSI input.
[3690268] The 10GbE ethernet port on the Clara AGX Developer Kit is not enabled due
to firmware issue, with fix pending.
Unfortunately not, The GLFW is initialized but not created.
"passing * -u $(id -u):$(id -g) to docker run, or running xhost +local:docker on your host ", do not work for me
I tested also the this container from Clara Holoscan Sample Applications | NVIDIA NGC, an dI got the same error.
