Ktx generated by cli of nvtt_export does not pass ktx validation
I am trying to convert .dds textures from the Bistro scene to KTX/KTX2 format for use with Vulkan.
Using the GUI version of NVTT Exporter, I can successfully convert the files. The generated KTX files pass ktx validate without errors and load correctly with the KTX library.
However, when I use the command-line interface:
nvtt_export hoo.dds -o hoo.ktx
the resulting KTX files do not work properly. Although ktx validate reports no errors, loading them with the KTX library fails.
Environment:
  • NVIDIA Texture Tools Exporter 2024.1.1
  • KTX tools v4.4.2
Is there any difference in default settings between the GUI and CLI versions that could explain this behavior?
Any guidance would be appreciated.
Thank you.
Hi @sanpe1 !
Could you try exporting to a file with the .ktx2 extension instead of .ktx, like this?
nvtt_export hoo.dds -o hoo.ktx2
nvtt_export doesn’t support exporting KTX version 1 files (.ktx), so when it sees that extension it instead exports its default, which is the DDS format. As a result, if you open hoo.ktx in a hex editor, you’ll probably see it start with the characters DDS , which is the signature for a DDS file. (This is a bit confusing; perhaps we should have nvtt_export print a warning when this happens.)
Let me know if that works!
Thank you for the suggestion.
I tried exporting with the .ktx2 extension using the CLI command you suggested:
This does produce a file whose header contains the ktx 20 signature, so it appears that a KTX2 file is being generated.
However, the behavior differs from the KTX2 file generated by the GUI when running ktx validate.
For the file created via the GUI, I get the following output:
ktx validate .\Antenna_Metal_BaseColor_by_GUI.ktx2
Validation successful
warning-6030: Deprecated unsized bytesPlanes in basic DFD block. Since specification 2.0.4 bytesPlanes must be sized (non-zero) for supercompressed textures.
    DFD block #1 bytesPlanes0 in basic DFD block is 0 but for KTX_SS_ZSTD supercompressed textures, since specification 2.0.4, it must be non-zero.
However, for the file created via the CLI, ktx validate produces no output at all—there is neither an error message nor a success message.
I also compared the header sections of the files generated by the GUI and CLI and observed differences between them.
It seems that the CLI-generated file may be missing something expected by ktx validate, but I am not sure what the exact cause is.
here is header of ktx2 made by CLI
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
and this is by GUI
That’s interesting! I think ktx validate is correct for the file created via the GUI, so thank you for pointing that out – NVTTE 2024’s KTX writer was based on the pre-2.0.4 KTX2 specification, so it is indeed writing 0 for bytesPlanes there (here’s the part of the source code that does that)! I’ll see if I can fix that.
I bet then the difference is that the GUI applies Zstandard supercompression by default, while the CLI doesn’t. So ktx validate probably succeeds on the CLI-generated .ktx2 file, but doesn’t print a message – and if you run echo %errorlevel% afterwards, it’ll probably print 0 (i.e. ktx validate didn’t crash, and instead exited with a success code). I forget why the CLI doesn’t apply Zstandard supercompression by default, but it could be because there’s no --no-zcmpoption to turn supercompression off, only a --zcmp option to turn it on.
So, if you run nvtt_export hoo.dds --zcmp 5 -o hoo.ktx2, then (hopefully) you should get identical files, and both should produce the same ktx validate message.
It worked!
Thank you so much!!
