Hi everyone, can anyone please help me to solve my issue???
I am trying to create a kubernetes cluster with Jetson TX2 board with ubuntu 16.04 installed. It have installed Jetpack software with it.
I installed docker and its version is Docker version 1.13.1, build 092cba3
Also I installed kubeadm, kubectl, kubelet and kubernetes-cni
I used kubeadm init command with calico network to create the cluster, it creates the cluster successfully, but the node is always in NotReady state.
So, I checked the available pods in the node using kubectl get pods --all-namespaces command and it shows,
NAMESPACE NAME READY STATUS RESTARTS AGE
kube-system calico-etcd-s4pvh 0/1 CrashLoopBackOff 9 25m
kube-system calico-kube-controllers-79dccdc4cc-qxv7g 0/1 Pending 0 25m
kube-system calico-node-f4jv7 0/2 CrashLoopBackOff 18 25m
kube-system etcd-tegra-ubuntu 1/1 Running 0 26m
kube-system kube-apiserver-tegra-ubuntu 1/1 Running 0 26m
kube-system kube-controller-manager-tegra-ubuntu 1/1 Running 0 26m
kube-system kube-dns-5c9ff5597-sqbtq 0/3 Pending 0 27m
kube-system kube-proxy-288dq 1/1 Running 0 27m
kube-system kube-scheduler-tegra-ubuntu 1/1 Running 0 26m
The above said pods are always in the crashloopbackoff ststus and the dns is always in pending status.
So, I checked the available docker images by using docker images command,
REPOSITORY TAG IMAGE ID CREATED SIZE
Quay latest b73ea5d87ea1 6 days ago 39.4 MB
arm64v8/ubuntu latest 0ff926db4f76 7 days ago 74.1 MB
k8s.gcr.io/kube-proxy-arm64 v1.10.4 0a4b69d28a6f 7 days ago 101 MB
k8s.gcr.io/kube-apiserver-arm64 v1.10.4 d58d0145769f 7 days ago 219 MB
k8s.gcr.io/kube-controller-manager-arm64 v1.10.4 88861ed2aedc 7 days ago 142 MB
k8s.gcr.io/kube-scheduler-arm64 v1.10.4 965113f16909 7 days ago 48.5 MB
Quay latest 7eca10056c8e 13 days ago 248 MB
Quay v3.0.8 6e991381712e 13 days ago 248 MB
Quay latest 240a82836573 13 days ago 55 MB
Quay latest 9f355e076ea7 13 days ago 68.8 MB
Quay v2.0.6 dbeb77ece97f 13 days ago 69.1 MB
Quay v3.0.7 411358ca98dc 3 weeks ago 248 MB
Quay v2.0.5 bf296711e770 7 weeks ago 69.1 MB
arm64v8/hello-world latest 993097e7b835 2 months ago 4.75 kB
k8s.gcr.io/etcd-arm64 3.1.12 db579ddd596b 3 months ago 181 MB
k8s.gcr.io/pause-arm64 3.1 6cf7c80fe444 5 months ago 525 kB
Quay v3.1.10 47bb9dd99916 11 months ago 34.6 MB
My question is, when we are using the kubeadm init command it should automatically pull the kube-apiserver, kube-controller-manager, kube-scheduler, etcd, kube-dns images. But here it is not pulling the dns image. Also, i checked the kube-dns pod status by using the kubectl describe pod --namespace=kube-system kube-dns-5c9ff5597-sqbtq command and it shows,
Namespace: kube-system
Node:
Labels: k8s-app=kube-dns
pod-template-hash=175991153
Annotations:
Status: Pending
IP:
Controlled By: ReplicaSet/kube-dns-5c9ff5597
Containers:
kubedns:
Image: k8s.gcr.io/k8s-dns-kube-dns-arm64:1.14.8
Ports: 10053/UDP, 10053/TCP, 10055/TCP
Host Ports: 0/UDP, 0/TCP, 0/TCP
Args:
–domain=cluster.local.
–dns-port=10053
–config-dir=/kube-dns-config
–v=2
Limits:
memory: 170Mi
Requests:
cpu: 100m
memory: 70Mi
Liveness: http-get http://:10054/healthcheck/kubedns delay=60s timeout=5s period=10s #success=1 #failure=5
Readiness: http-get http://:8081/readiness delay=3s timeout=5s period=10s #success=1 #failure=3
Environment:
PROMETHEUS_PORT: 10055
Mounts:
/kube-dns-config from kube-dns-config (rw)
/var/run/secrets/kubernetes.io/serviceaccount from kube-dns-token-gr99l (ro)
dnsmasq:
Image: k8s.gcr.io/k8s-dns-dnsmasq-nanny-arm64:1.14.8
Ports: 53/UDP, 53/TCP
Args:
-v=2
-logtostderr
-configDir=/etc/k8s/dns/dnsmasq-nanny
-restartDnsmasq=true
-k
–cache-size=1000
–no-negcache
–log-facility=-
–server=/cluster.local/127.0.0.1#10053
–server=/in-addr.arpa/127.0.0.1#10053
–server=/ip6.arpa/127.0.0.1#10053
Requests:
cpu: 150m
memory: 20Mi
Liveness: http-get http://:10054/healthcheck/dnsmasq delay=60s timeout=5s period=10s #success=1 #failure=5
Environment:
Mounts:
/etc/k8s/dns/dnsmasq-nanny from kube-dns-config (rw)
sidecar:
Image: k8s.gcr.io/k8s-dns-sidecar-arm64:1.14.8
Port: 10054/TCP
Host Port: 0/TCP
Args:
–v=2
–logtostderr
–probe=kubedns,127.0.0.1:10053,kubernetes.default.svc.cluster.local,5,SRV
–probe=dnsmasq,127.0.0.1:53,kubernetes.default.svc.cluster.local,5,SRV
Requests:
cpu: 10m
memory: 20Mi
Liveness: http-get http://:10054/metrics delay=60s timeout=5s period=10s #success=1 #failure=5
Environment:
Mounts:
Conditions:
Type Status
PodScheduled False
Volumes:
kube-dns-config:
Type: ConfigMap (a volume populated by a ConfigMap)
Optional: true
kube-dns-token-gr99l:
Type: Secret (a volume populated by a Secret)
SecretName: kube-dns-token-gr99l
Optional: false
QoS Class: Burstable
Node-Selectors:
Tolerations: CriticalAddonsOnly
node-role.kubernetes.io/master:NoSchedule
node.kubernetes.io/not-ready:NoExecute for 300s
node.kubernetes.io/unreachable:NoExecute for 300s
Events:
Type Reason Age From Message
Warning FailedScheduling 7s (x107 over 30m) default-scheduler 0/1 nodes are available: 1 node(s) were not ready.
Please help me to solve this issue.
