I am trying to create a kubernetes cluster with kubespray.
I have run it as per the document but I get the following error.
What should I do in this case?
TASK [kubernetes/node : Modprobe Kernel Module for IPVS] ***********************************************
changed: [node2] => (item=ip_vs)
changed: [node1] => (item=ip_vs)
changed: [node2] => (item=ip_vs_rr)
changed: [node1] => (item=ip_vs_rr)
failed: [node2] (item=ip_vs_wrr) => {"ansible_loop_var": "item", "changed": false, "item": "ip_vs_wrr", "msg": "modprobe: FATAL: Module ip_vs_wrr not found in directory /lib/modules/4.9.253-tegra\n", "name": "ip_vs_wrr", "params": "", "rc": 1, "state": "present", "stderr": "modprobe: FATAL: Module ip_vs_wrr not found in directory /lib/modules/4.9.253-tegra\n", "stderr_lines": ["modprobe: FATAL: Module ip_vs_wrr not found in directory /lib/modules/4.9.253-tegra"], "stdout": "", "stdout_lines": []}
failed: [node1] (item=ip_vs_wrr) => {"ansible_loop_var": "item", "changed": false, "item": "ip_vs_wrr", "msg": "modprobe: FATAL: Module ip_vs_wrr not found in directory /lib/modules/4.9.253-tegra\n", "name": "ip_vs_wrr", "params": "", "rc": 1, "state": "present", "stderr": "modprobe: FATAL: Module ip_vs_wrr not found in directory /lib/modules/4.9.253-tegra\n", "stderr_lines": ["modprobe: FATAL: Module ip_vs_wrr not found in directory /lib/modules/4.9.253-tegra"], "stdout": "", "stdout_lines": []}
failed: [node2] (item=ip_vs_sh) => {"ansible_loop_var": "item", "changed": false, "item": "ip_vs_sh", "msg": "modprobe: FATAL: Module ip_vs_sh not found in directory /lib/modules/4.9.253-tegra\n", "name": "ip_vs_sh", "params": "", "rc": 1, "state": "present", "stderr": "modprobe: FATAL: Module ip_vs_sh not found in directory /lib/modules/4.9.253-tegra\n", "stderr_lines": ["modprobe: FATAL: Module ip_vs_sh not found in directory /lib/modules/4.9.253-tegra"], "stdout": "", "stdout_lines": []}
failed: [node1] (item=ip_vs_sh) => {"ansible_loop_var": "item", "changed": false, "item": "ip_vs_sh", "msg": "modprobe: FATAL: Module ip_vs_sh not found in directory /lib/modules/4.9.253-tegra\n", "name": "ip_vs_sh", "params": "", "rc": 1, "state": "present", "stderr": "modprobe: FATAL: Module ip_vs_sh not found in directory /lib/modules/4.9.253-tegra\n", "stderr_lines": ["modprobe: FATAL: Module ip_vs_sh not found in directory /lib/modules/4.9.253-tegra"], "stdout": "", "stdout_lines": []}
■executed command
ansible-playbook -i inventory/mycluster/hosts.yml --become --become-user=root cluster.yml -u ubuntu -kK
■document
https://docs.nvidia.com/networking/m/view-rendered-page.action?abstractPageId=19818992
