delayed_cache_work_func
Detected that the function executes millions of times per second
Is there any problem in the function that can’t be quit.
static void __cache_work_func(struct mlx5_cache_ent *ent)
struct mlx5_ib_dev *dev = ent->dev;
struct mlx5_mr_cache *cache = &dev->cache;
int i = order2idx(dev, ent->order);
int err;
s64 dtime;
if (cache->stopped)
return;
ent = &dev->cache.ent[i];
if (ent->cur < 2 * ent->limit && !dev->fill_delay) {
err = add_keys(dev, i, 1);
if (ent->cur < 2 * ent->limit) {
if (err == -EAGAIN) {
mlx5_ib_dbg(dev, “returned eagain, order %d\n”,
i + 2);
cancel_delayed_work(&ent->dwork);
queue_delayed_work(cache->wq, &ent->dwork,
msecs_to_jiffies(3));
} else if (err) {
mlx5_ib_warn(dev, “command failed order %d, err %d\n”,
i + 2, err);
msecs_to_jiffies(1000));
} else {
queue_work(cache->wq, &ent->work);
} else if (ent->cur > 2 * ent->limit) {
The remove_keys() logic is performed as garbage collection
task. Such task is intended to be run when no other active
processes are running.
The need_resched() will return TRUE if there are user tasks
to be activated in near future.
In such case, we don’t execute remove_keys() and postpone
the garbage collection work to try to run in next cycle,
in order to free CPU resources to other tasks.
dtime = (cache->last_add + (s64)cache->rel_timeout * HZ) -
jiffies;
if (cache->rel_imm ||
(cache->rel_timeout >= 0 && !someone_adding(cache) &&
dtime <= 0)) {
remove_keys(dev, i, 1);
if (ent->cur > ent->limit)
} else if (cache->rel_timeout >= 0) {
dtime = max_t(s64, dtime, 0);
dtime = min_t(s64, dtime, (MAX_MR_RELEASE_TIMEOUT * HZ));
queue_delayed_work(cache->wq, &ent->dwork, dtime);
} else if (cache->rel_imm && !someone_releasing(cache)) {
cache->rel_imm = 0;
static void delayed_cache_work_func(struct work_struct *work)
struct mlx5_cache_ent *ent;
ent = container_of(work, struct mlx5_cache_ent, dwork.work);
__cache_work_func(ent);
