HI @udemirezen
Thanks for your interest in Modulus. Responses to your questions are sectioned below:
How can I use l-bfgs optimizer? I can not find any example. I want to use it just by itself. and also, I want to use it after an optimization period by using adam optimizer then l-bfgs optimizer. Several papers used this approach. how can I use Adahessian optimizer. Agai I can not find any example.
Switching between optimizers should be as simple as changing the your config.yaml
file. There’s info on optimizers we support in the config in the user-guide. Related source code if you are familiar with Hydra. For example:
defaults :
- modulus_default
- arch:
- fully_connected
- scheduler: tf_exponential_lr
- optimizer: adahessian # or bfgs
- loss: sum
- _self_
optimizer:
lr: 1e-3
The reason why we have no examples that use L-BFGS / AdaHessian is that typically we have found that Adam works. But its still great to experiment with these. Note that you may have to tune the parameters of the optimizer which can be done in the yaml as well. The parameters you can control / defaults are found here.
During the training I only want to save the best model. But as far as I see, periodically given a parameter value, modulus saves models sequentially. How can I save only the best model?
If your training is set up correctly and stable, the best model should be the model at the end of training which should have the lowest training/validation loss if there is no over fitting. If you’re interested in early stopping based on validation error have a look at the stop criteria utility which can be set up in your config (there is presently a bug with this feature, please see this post with the fix).
