On TX1 , gst-launch-1.0 works fine , but i have issu without Error in C++ apps :
ubuntu@tegra-ubuntu:~$ gst-launch-1.0 videotestsrc is-live=true ! video/x-raw, format=I420, width=1640, height=1232, framerate=30/1 ! videorate ! video/x-raw, framerate=1/10 ! queue ! nvjpegenc ! fakesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:10.777120569
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
But, in my “main” application ( write in C++), i use TX1 28.1 and call the Gstreamer 1.0 plugin nvjpegdec :
mVideoSourceConvert = gst_element_factory_make("<b>nvjpegdec</b>", EXTRANAME("nvjpegdec_"));
GstCaps *lnvcaps = gst_caps_new_simple ("video/x-raw",
"format", G_TYPE_STRING,"I420",
NULL);
g_object_set (G_OBJECT (mVideoSourceConvert), "caps", lnvcaps, NULL);
gst_caps_unref (lnvcaps);
I have crash with :
Oct 31 12:52:18 tegra-ubuntu MAIN: gstApp makeElementSource
Oct 31 12:52:18 tegra-ubuntu kernel: [ 8646.746636] main[20091]: PC Alignment exception: pc=e9a2c859cbbd9656 sp=e9a2c859cbbd9656
or Sometimes , i havekernel error like this :
Oct 31 12:51:46 tegra-ubuntu MAIN: gstApp makeElementSource
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.401939] main[20066]: unhandled level 0 translation fault (11) at 0xdac39389c7bfe1f0, esr 0x83000004
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.411795] pgd = ffffffc0437b0000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.415200] [dac39389c7bfe1f0] *pgd=0000000000000000, *pud=0000000000000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.422575]
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.424199] CPU: 0 PID: 20066 Comm: main Not tainted 4.4.38-tegra #1
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.431142] Hardware name: jetson_cv (DT)
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.435272] task: ffffffc0e052d780 ti: ffffffc089390000 task.ti: ffffffc089390000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.443031] PC is at 0xdac39389c7bfe1f0
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.446954] LR is at 0xdac39389c7bfe1f0
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.450895] pc : [<dac39389c7bfe1f0>] lr : [<dac39389c7bfe1f0>] pstate: 20000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.458362] sp : dac39389c7bfe1f0
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.461773] x29: 0000000000000000 x28: 0000000000000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.467182] x27: 0000000000000000 x26: 0000000000000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.472663] x25: 0000000000000000 x24: 0000000000000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.478140] x23: 0000000000000000 x22: 0000000000000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.483583] x21: 0000000000000000 x20: 0000000000000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.488990] x19: 0000000000000000 x18: 0000007fb6056000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.494394] x17: 0000007fb5c60318 x16: 0000007fb371c698
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.499802] x15: 0000007fb611d000 x14: 0000000000000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.505211] x13: 0000000000000000 x12: 0000000000000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.510603] x11: 0000000000000018 x10: 0101010101010101
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.515993] x9 : 0000000000000004 x8 : 000000000000007e
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.521406] x7 : 0000007fb425ab10 x6 : 0000007fb425a900
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.526807] x5 : dac39389c7bfe1f0 x4 : 0000000000000000
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.532211] x3 : dac39389c7bfe1f0 x2 : 0000007fb611dcb0
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.537644] x1 : 0000000000000001 x0 : 0000000000000001
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.543076]
Oct 31 12:51:46 tegra-ubuntu kernel: [ 8614.544630] vdso base = 0x7fb611c000
I try to open one camera with Gstrreamer , but it’s didn’t work.
G_DEBUG="fatal_criticals" gdb ./shimaore
Gdb can’t give more information , and no error …
MAIN : LEFT = 1-3addCameraConfig : add id 1:0F2CD300
gstApp makeElementFactory
0:00:02.645842759 20192 0x506780 LOG GST_ELEMENT_FACTORY gstelementfactory.c:439:gst_element_factory_make: gstelementfactory: make "v4l2src" "(NULL)"
0:00:02.646534947 20192 0x506780 LOG GST_ELEMENT_FACTORY gstelementfactory.c:445:gst_element_factory_make:<v4l2src> found factory 0x474390
0:00:02.646956093 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstpluginfeature.c:106:gst_plugin_feature_load: loading plugin for feature 0x474390; 'v4l2src'
0:00:02.647565624 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstpluginfeature.c:110:gst_plugin_feature_load: loading plugin video4linux2
0:00:02.647981770 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstplugin.c:1261:gst_plugin_load_by_name: looking up plugin video4linux2 in default registry
0:00:02.648605832 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstplugin.c:1264:gst_plugin_load_by_name: loading plugin video4linux2 from file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so
0:00:02.648906718 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstplugin.c:716:_priv_gst_plugin_load_file_for_registry: attempt to load plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so"
in : udev_device_new_from_syspath
Device Entry Path 1-3 => /sys/devices/70090000.xusb/usb1/1-1/1-1.3/1-1.3:1.0/video4linux/video1
RAWDEVICE not match with 1-3
Device Entry Path 1-3 => /sys/devices/70090000.xusb/usb1/1-3/1-3:1.0/video4linux/video0
Device Node Path: /dev/video0 Device Node ID busnum : 1 (1), devnum : 3 (3) Device Node ID busnum : 3 (3), SubSystem : 1-3 Serial: 0825D300 Vendor: 2560 Product: c1d0
0:00:02.703534634 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:817:_priv_gst_plugin_load_file_for_registry: Plugin 0x46f570 for file "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so" prepared, calling entry function...
0:00:02.703595624 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:824:_priv_gst_plugin_load_file_for_registry: Plugin 0x46f570 for file "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so" prepared, registering...
0:00:02.703633593 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:505:gst_plugin_register_func: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so" looks good
0:00:02.703690364 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category v4l2 matches pattern 0x43cc20 - gets set to level 6
0:00:02.703818853 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:1777:gst_plugin_add_dependency:<plugin28> dependency already registered
0:00:02.703932082 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category pushsrc matches pattern 0x43cc20 - gets set to level 6
0:00:02.704116978 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x474390 (v4l2src)
0:00:02.704214634 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4742b0 (v4l2sink)
0:00:02.704257134 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4741d0 (v4l2radio)
0:00:02.704334582 20192 0x506780 DEBUG GST_DEVICE_PROVIDER_FACTORY gstdeviceproviderfactory.c:190:gst_device_provider_register:<registry0> update existing feature 0x45e0d0 (v4l2deviceprovider)
0:00:02.704378332 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:532:gst_plugin_register_func: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so" initialised
0:00:02.704415520 20192 0x506780 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so" loaded
0:00:02.704449478 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstpluginfeature.c:115:gst_plugin_feature_load: loaded plugin video4linux2
0:00:02.704485259 20192 0x506780 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "v4l2src"
0:00:02.704517447 20192 0x506780 DEBUG GST_ELEMENT_PADS gstelement.c:281:gst_element_base_class_init: type GstBaseSrc : factory (nil)
0:00:02.704555155 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category basesrc matches pattern 0x43cc20 - gets set to level 6
0:00:02.704735416 20192 0x506780 DEBUG GST_ELEMENT_PADS gstelement.c:281:gst_element_base_class_init: type GstPushSrc : factory (nil)
0:00:02.704768905 20192 0x506780 DEBUG GST_ELEMENT_PADS gstelement.c:281:gst_element_base_class_init: type GstV4l2Src : factory 0x474390
0:00:02.705014478 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x31424752 RGB1
0:00:02.705061353 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x35315241 AR15
0:00:02.705119999 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0xb5315241 AR1.
0:00:02.705214791 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x52424752 RGBR
0:00:02.705250416 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x48524742 BGRH
0:00:02.705320572 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x34343452 R444
0:00:02.705435155 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x20343059 Y04
0:00:02.705471978 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x20363059 Y06
0:00:02.705511718 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x20303159 Y10
0:00:02.705532864 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x20323159 Y12
0:00:02.705621718 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x42303159 Y10B
0:00:02.705654739 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x384c4150 PAL8
0:00:02.705694166 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x20385655 UV8
0:00:02.705779530 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x31324d59 YM21
0:00:02.705822499 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x56555959 YYUV
0:00:02.705908697 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x59555956 VYUY
0:00:02.705957551 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x50313459 Y41P
0:00:02.705991353 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x34343459 Y444
0:00:02.706066874 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x4f565559 YUVO
0:00:02.706100364 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x50565559 YUVP
0:00:02.706137864 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x34565559 YUV4
0:00:02.706176197 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x34324948 HI24
0:00:02.706208228 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x32314d48 HM12
0:00:02.706281822 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x3032344d M420
0:00:02.706330312 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x32314d56 VM12
0:00:02.706412291 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x3234564e NV42
0:00:02.706477343 20192 0x506780 DEBUG v4l2 gstv4l2object.c:1476:gst_v4l2_object_v4l2fourcc_to_bare_struct: Unsupported fourcc 0x3436324d M264
0:00:02.707846666 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category v4l2src matches pattern 0x43cc20 - gets set to level 6
0:00:02.707946457 20192 0x506780 DEBUG basesrc gstbasesrc.c:445:gst_base_src_init:<GstBaseSrc@0x7fb000e1b0> creating src pad
0:00:02.708054739 20192 0x506780 DEBUG basesrc gstbasesrc.c:448:gst_base_src_init:<GstBaseSrc@0x7fb000e1b0> setting functions on src pad
0:00:02.708095416 20192 0x506780 DEBUG GST_PADS gstpad.c:1708:gst_pad_set_activatemode_function_full:<'':src> activatemodefunc set to gst_base_src_activate_mode
0:00:02.708168072 20192 0x506780 DEBUG GST_PADS gstpad.c:1849:gst_pad_set_event_function_full:<'':src> eventfunc for set to gst_base_src_event
0:00:02.708218697 20192 0x506780 DEBUG GST_PADS gstpad.c:1929:gst_pad_set_query_function_full:<'':src> queryfunc set to gst_base_src_query
0:00:02.708258437 20192 0x506780 DEBUG GST_PADS gstpad.c:1816:gst_pad_set_getrange_function_full:<'':src> getrangefunc set to gst_base_src_getrange
0:00:02.708298749 20192 0x506780 DEBUG basesrc gstbasesrc.c:456:gst_base_src_init:<GstBaseSrc@0x7fb000e1b0> adding src pad
0:00:02.708320780 20192 0x506780 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSrc@0x7fb000e1b0> adding pad 'src'
0:00:02.708343905 20192 0x506780 DEBUG GST_REFCOUNTING gstobject.c:692:gst_object_set_parent:<'':src> set parent (ref and sink)
0:00:02.708432447 20192 0x506780 DEBUG basesrc gstbasesrc.c:473:gst_base_src_init:<GstBaseSrc@0x7fb000e1b0> init done
0:00:02.708486718 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:390:gst_element_factory_create: created element "v4l2src"
gstApp mDevicePath : /dev/video1
0:00:02.708617551 20192 0x506780 LOG GST_ELEMENT_FACTORY gstelementfactory.c:439:gst_element_factory_make: gstelementfactory: make "filesink" "(NULL)"
0:00:02.708664270 20192 0x506780 LOG GST_ELEMENT_FACTORY gstelementfactory.c:445:gst_element_factory_make:<filesink> found factory 0x4c82f0
0:00:02.708687551 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstpluginfeature.c:106:gst_plugin_feature_load: loading plugin for feature 0x4c82f0; 'filesink'
0:00:02.708707499 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstpluginfeature.c:110:gst_plugin_feature_load: loading plugin coreelements
0:00:02.708725364 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstplugin.c:1261:gst_plugin_load_by_name: looking up plugin coreelements in default registry
0:00:02.708816926 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstplugin.c:1264:gst_plugin_load_by_name: loading plugin coreelements from file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so
0:00:02.708854947 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstplugin.c:716:_priv_gst_plugin_load_file_for_registry: attempt to load plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so"
0:00:02.722614895 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:817:_priv_gst_plugin_load_file_for_registry: Plugin 0x4bae70 for file "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" prepared, calling entry function...
0:00:02.722670676 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:824:_priv_gst_plugin_load_file_for_registry: Plugin 0x4bae70 for file "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" prepared, registering...
0:00:02.722708905 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:505:gst_plugin_register_func: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" looks good
0:00:02.722804374 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category capsfilter matches pattern 0x43cc20 - gets set to level 6
0:00:02.722851926 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4cb1a0 (capsfilter)
0:00:02.722937864 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category concat matches pattern 0x43cc20 - gets set to level 6
0:00:02.722984999 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4cb0c0 (concat)
0:00:02.723030520 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category downloadbuffer matches pattern 0x43cc20 - gets set to level 6
0:00:02.723078020 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c9ea0 (downloadbuffer)
0:00:02.723162864 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category fakesrc matches pattern 0x43cc20 - gets set to level 6
0:00:02.723198749 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c9dc0 (fakesrc)
0:00:02.723230624 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category fakesink matches pattern 0x43cc20 - gets set to level 6
0:00:02.723301562 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c9ce0 (fakesink)
0:00:02.723405259 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category fdsrc matches pattern 0x43cc20 - gets set to level 6
0:00:02.723491301 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c9c00 (fdsrc)
0:00:02.723540780 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category fdsink matches pattern 0x43cc20 - gets set to level 6
0:00:02.723583541 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c9b20 (fdsink)
0:00:02.723628853 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category filesrc matches pattern 0x43cc20 - gets set to level 6
0:00:02.723726874 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c9a40 (filesrc)
0:00:02.723771041 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category funnel matches pattern 0x43cc20 - gets set to level 6
0:00:02.723813645 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c9960 (funnel)
0:00:02.723860676 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category identity matches pattern 0x43cc20 - gets set to level 6
0:00:02.723920155 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c9880 (identity)
0:00:02.723973801 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category input-selector matches pattern 0x43cc20 - gets set to level 6
0:00:02.724015155 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c8670 (input-selector)
0:00:02.724075155 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category output-selector matches pattern 0x43cc20 - gets set to level 6
0:00:02.724106666 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c8590 (output-selector)
0:00:02.724177551 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category queue matches pattern 0x43cc20 - gets set to level 6
0:00:02.724216509 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category queue_dataflow matches pattern 0x43cc20 - gets set to level 6
0:00:02.724256145 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c84b0 (queue)
0:00:02.724304687 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category queue2 matches pattern 0x43cc20 - gets set to level 6
0:00:02.724331562 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category queue2_dataflow matches pattern 0x43cc20 - gets set to level 6
0:00:02.724358593 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c83d0 (queue2)
0:00:02.724391509 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category filesink matches pattern 0x43cc20 - gets set to level 6
0:00:02.724476249 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c82f0 (filesink)
0:00:02.724519843 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category tee matches pattern 0x43cc20 - gets set to level 6
0:00:02.724562603 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c8210 (tee)
0:00:02.724611562 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category typefind matches pattern 0x43cc20 - gets set to level 6
0:00:02.724642291 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c8130 (typefind)
0:00:02.724669947 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category multiqueue matches pattern 0x43cc20 - gets set to level 6
0:00:02.724745364 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c8050 (multiqueue)
0:00:02.724789947 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category valve matches pattern 0x43cc20 - gets set to level 6
0:00:02.724832239 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c56a0 (valve)
0:00:02.724877968 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category streamiddemux matches pattern 0x43cc20 - gets set to level 6
0:00:02.724947864 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4c55c0 (streamiddemux)
0:00:02.724985937 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:532:gst_plugin_register_func: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" initialised
0:00:02.725020676 20192 0x506780 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:02.725064166 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstpluginfeature.c:115:gst_plugin_feature_load: loaded plugin coreelements
0:00:02.725093905 20192 0x506780 INFO GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create: creating element "filesink"
0:00:02.725179322 20192 0x506780 DEBUG GST_ELEMENT_PADS gstelement.c:281:gst_element_base_class_init: type GstBaseSink : factory (nil)
0:00:02.725218593 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category basesink matches pattern 0x43cc20 - gets set to level 6
0:00:02.725353593 20192 0x506780 DEBUG GST_ELEMENT_PADS gstelement.c:281:gst_element_base_class_init: type GstFileSink : factory 0x4c82f0
0:00:02.725504530 20192 0x506780 DEBUG GST_PADS gstpad.c:1673:gst_pad_set_activate_function_full:<'':sink> activatefunc set to gst_base_sink_pad_activate
0:00:02.725532864 20192 0x506780 DEBUG GST_PADS gstpad.c:1708:gst_pad_set_activatemode_function_full:<'':sink> activatemodefunc set to gst_base_sink_pad_activate_mode
0:00:02.725556874 20192 0x506780 DEBUG GST_PADS gstpad.c:1929:gst_pad_set_query_function_full:<'':sink> queryfunc set to gst_base_sink_sink_query
0:00:02.725591405 20192 0x506780 DEBUG GST_PADS gstpad.c:1849:gst_pad_set_event_function_full:<'':sink> eventfunc for set to gst_base_sink_event
0:00:02.725678437 20192 0x506780 DEBUG GST_PADS gstpad.c:1743:gst_pad_set_chain_function_full:<'':sink> chainfunc set to gst_base_sink_chain
0:00:02.725716978 20192 0x506780 DEBUG GST_PADS gstpad.c:1780:gst_pad_set_chain_list_function_full:<'':sink> chainlistfunc set to gst_base_sink_chain_list
0:00:02.725756822 20192 0x506780 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSink@0x7fb0016210> adding pad 'sink'
0:00:02.725780051 20192 0x506780 DEBUG GST_REFCOUNTING gstobject.c:692:gst_object_set_parent:<'':sink> set parent (ref and sink)
0:00:02.725872603 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:390:gst_element_factory_create: created element "filesink"
0:00:02.726102916 20192 0x506780 LOG GST_ELEMENT_FACTORY gstelementfactory.c:439:gst_element_factory_make: gstelementfactory: make "nvjpegdec" "nvjpegdec_1"
0:00:02.726144478 20192 0x506780 LOG GST_ELEMENT_FACTORY gstelementfactory.c:445:gst_element_factory_make:<nvjpegdec> found factory 0x4713f0
0:00:02.726201353 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstpluginfeature.c:106:gst_plugin_feature_load: loading plugin for feature 0x4713f0; 'nvjpegdec'
0:00:02.726234009 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstpluginfeature.c:110:gst_plugin_feature_load: loading plugin nvjpeg
0:00:02.726268905 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstplugin.c:1261:gst_plugin_load_by_name: looking up plugin nvjpeg in default registry
0:00:02.726310728 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstplugin.c:1264:gst_plugin_load_by_name: loading plugin nvjpeg from file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvgstjpeg.so
0:00:02.726344374 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstplugin.c:716:_priv_gst_plugin_load_file_for_registry: attempt to load plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvgstjpeg.so"
Video4linuxInterface::getCameraConfig : /dev/video0 : getCameraControl V4L2_CID_EXPOSURE_AUTO
Video4linuxInterface::getCameraConfig : /dev/video0 : getCameraControl V4L2_CID_AUTO_WHITE_BALANCE
Video4linuxInterface::getCameraConfig : /dev/video0 : getCameraControl V4L2_CID_GAIN
Video4linuxInterface::getCameraConfig : /dev/video0 : getCameraControl V4L2_CID_EXPOSURE_ABSOLUTE
Video4linuxInterface::getCameraConfig : /dev/video0 : getCameraControl V4L2_CID_WHITE_BALANCE_TEMPERATURE
Video4linuxInterface::getCameraConfig : DEVICE /dev/video0 : 0 : 0 : 0 : 312 : 2500
END : udev_list_entry_foreach
camera : Number = 2
END : search camera WARNING : MAIN : BUS 1-3 ( left ) with no camera connected
0:00:02.793238645 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:817:_priv_gst_plugin_load_file_for_registry: Plugin 0x46f070 for file "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvgstjpeg.so" prepared, calling entry function...
0:00:02.793278384 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:824:_priv_gst_plugin_load_file_for_registry: Plugin 0x46f070 for file "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvgstjpeg.so" prepared, registering...
0:00:02.793295937 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:505:gst_plugin_register_func: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvgstjpeg.so" looks good
0:00:02.793375051 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4714d0 (nvjpegenc)
0:00:02.793432082 20192 0x506780 DEBUG GST_ELEMENT_FACTORY gstelementfactory.c:225:gst_element_register:<registry0> update existing feature 0x4713f0 (nvjpegdec)
0:00:02.793451614 20192 0x506780 LOG GST_PLUGIN_LOADING gstplugin.c:532:gst_plugin_register_func: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvgstjpeg.so" initialised
0:00:02.793467082 20192 0x506780 INFO GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libnvgstjpeg.so" loaded
0:00:02.793489582 20192 0x506780 DEBUG GST_PLUGIN_LOADING gstpluginfeature.c:115:gst_plugin_feature_load: loaded plugin nvjpeg
0:00:02.793517968 20192 0x506780 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element "nvjpegdec" named "nvjpegdec_1"
0:00:02.793541666 20192 0x506780 DEBUG GST_ELEMENT_PADS gstelement.c:281:gst_element_base_class_init: type GstVideoDecoder : factory (nil)
0:00:02.793571874 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category videodecoder matches pattern 0x43cc20 - gets set to level 6
0:00:02.793647707 20192 0x506780 DEBUG GST_ELEMENT_PADS gstelement.c:281:gst_element_base_class_init: type GstNvJpegDec : factory 0x4713f0
0:00:02.793711874 20192 0x506780 DEBUG structure gststructure.c:2316:gst_structure_parse_field: trying field name 'format'
0:00:02.793743957 20192 0x506780 DEBUG structure gststructure.c:2367:gst_structure_parse_value: trying type name 'string'
0:00:02.793817134 20192 0x506780 DEBUG structure gststructure.c:2316:gst_structure_parse_field: trying field name 'width'
0:00:02.793842551 20192 0x506780 DEBUG structure gststructure.c:2367:gst_structure_parse_value: trying type name 'int'
0:00:02.793872603 20192 0x506780 DEBUG structure gststructure.c:2316:gst_structure_parse_field: trying field name 'height'
0:00:02.793902239 20192 0x506780 DEBUG structure gststructure.c:2367:gst_structure_parse_value: trying type name 'int'
0:00:02.793956509 20192 0x506780 DEBUG structure gststructure.c:2316:gst_structure_parse_field: trying field name 'framerate'
0:00:02.793978645 20192 0x506780 DEBUG structure gststructure.c:2367:gst_structure_parse_value: trying type name 'fraction'
0:00:02.794053020 20192 0x506780 DEBUG structure gststructure.c:2316:gst_structure_parse_field: trying field name 'format'
0:00:02.794080364 20192 0x506780 DEBUG structure gststructure.c:2367:gst_structure_parse_value: trying type name 'string'
0:00:02.794136301 20192 0x506780 DEBUG structure gststructure.c:2316:gst_structure_parse_field: trying field name 'width'
0:00:02.794159999 20192 0x506780 DEBUG structure gststructure.c:2367:gst_structure_parse_value: trying type name 'int'
0:00:02.794185312 20192 0x506780 DEBUG structure gststructure.c:2316:gst_structure_parse_field: trying field name 'height'
0:00:02.794210103 20192 0x506780 DEBUG structure gststructure.c:2367:gst_structure_parse_value: trying type name 'int'
0:00:02.794227239 20192 0x506780 DEBUG structure gststructure.c:2316:gst_structure_parse_field: trying field name 'framerate'
0:00:02.794245884 20192 0x506780 DEBUG structure gststructure.c:2367:gst_structure_parse_value: trying type name 'fraction'
0:00:02.794381770 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category jpegdec matches pattern 0x43cc20 - gets set to level 6
0:00:02.794426614 20192 0x506780 DEBUG videodecoder gstvideodecoder.c:560:gst_video_decoder_init:<GstVideoDecoder@0x7fb00211a0> gst_video_decoder_init
0:00:02.794499114 20192 0x506780 DEBUG GST_PADS gstpad.c:1743:gst_pad_set_chain_function_full:<'':sink> chainfunc set to gst_video_decoder_chain
0:00:02.794533124 20192 0x506780 DEBUG GST_PADS gstpad.c:1849:gst_pad_set_event_function_full:<'':sink> eventfunc for set to gst_video_decoder_sink_event
0:00:02.794566405 20192 0x506780 DEBUG GST_PADS gstpad.c:1929:gst_pad_set_query_function_full:<'':sink> queryfunc set to gst_video_decoder_sink_query
0:00:02.794587395 20192 0x506780 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstVideoDecoder@0x7fb00211a0> adding pad 'sink'
0:00:02.794602812 20192 0x506780 DEBUG GST_REFCOUNTING gstobject.c:692:gst_object_set_parent:<'':sink> set parent (ref and sink)
0:00:02.794667030 20192 0x506780 DEBUG GST_PADS gstpad.c:1849:gst_pad_set_event_function_full:<'':src> eventfunc for set to gst_video_decoder_src_event
0:00:02.794695416 20192 0x506780 DEBUG GST_PADS gstpad.c:1929:gst_pad_set_query_function_full:<'':src> queryfunc set to gst_video_decoder_src_query
0:00:02.794720520 20192 0x506780 INFO GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstVideoDecoder@0x7fb00211a0> adding pad 'src'
0:00:02.794755051 20192 0x506780 DEBUG GST_REFCOUNTING gstobject.c:692:gst_object_set_parent:<'':src> set parent (ref and sink)
0:00:02.794809218 20192 0x506780 LOG GST_DEBUG gstinfo.c:1462:gst_debug_reset_threshold: category adapter matches pattern 0x43cc20 - gets set to level 6
0:00:02.794899478 20192 0x506780 DEBUG videodecoder gstvideodecoder.c:1983:gst_video_decoder_reset:<GstVideoDecoder@0x7fb00211a0> reset full 1
0:00:02.794960728 20192 0x506780 DEBUG jpegdec gstjpegdec.c:273:gst_jpeg_dec_init: initializing
Thread 2 "shimaore" received signal SIGBUS, Bus error.
[Switching to Thread 0x7fb5ed6ee0 (LWP 20196)]
0x00607a88dccc2c9d in ?? ()
(gdb) bt
#0 0x00607a88dccc2c9d in ?? ()
#1 0x49607a88dccc2c9d in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
if you are an idea … thx
