L4T 35.1 Orin AGX target.
Kernel built using tegra_defcong for 5.10.104 kernel, no changes. Simple recompiled from source to set a going forward benchmark for product development.
No changes to Orin p3737 device tree.
Flashed emmc using flash.sh
Kernel panic in tegra_qspi_isr_thread
Unsure how to reproduce this kernel panic.
[ 14.492152] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 14.498781] systemd[1]: Starting udev Coldplug all Devices...
[ 14.506270] systemd[1]: Started Journal Service.
[ 14.538476] systemd-journald[314]: Received client request to flush runtime j
ournal.
[ 14.550743] systemd-journald[314]: File /var/log/journal/6b0b968df0625e0ab6c0
2ed46345ab72/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 14.877185] using random self ethernet address
[ 14.881886] using random host ethernet address
[ 17.027911] tegra23x-qspi 3270000.spi: QSPI get spurious interrupt, Status =
0x00400005
[ 17.036286] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000010
[ 17.045378] Mem abort info:
[ 17.048246] ESR = 0x96000004
[ 17.051393] EC = 0x25: DABT (current EL), IL = 32 bits
[ 17.056855] SET = 0, FnV = 0
[ 17.060001] EA = 0, S1PTW = 0
[ 17.063222] Data abort info:
[ 17.066178] ISV = 0, ISS = 0x00000004
[ 17.070121] CM = 0, WnR = 0
[ 17.073181] user pgtable: 4k pages, 48-bit VAs, pgdp=000000010b354000
[ 17.079803] [0000000000000010] pgd=0000000000000000, p4d=0000000000000000
[ 17.086800] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 17.092531] Modules linked in:
[ 17.095681] CPU: 0 PID: 197 Comm: irq/72-3270000. Not tainted 5.10.104.0-FLIR
#1
[ 17.103304] Hardware name: /, BIOS 1.0-d7fb19b 08/10/2022
[ 17.108939] pstate: 40c00089 (nZcv daIf +PAN +UAO -TCO BTYPE=--)
[ 17.115132] pc : tegra_qspi_isr_thread+0x15c/0x330
[ 17.120054] lr : tegra_qspi_isr_thread+0x12c/0x330
[ 17.124986] sp : ffff80001276bd30
[ 17.128387] x29: ffff80001276bd30 x28: ffff1321c6675700
[ 17.133847] x27: ffff1321c6675700 x26: ffffc686b5d1f480
[ 17.139314] x25: 0000000000000001 x24: ffffc686b5d1f558
[ 17.144773] x23: 0000000000000000 x22: ffff1321c6964690
[ 17.150234] x21: 0000000000000000 x20: 0000000000000000
[ 17.155697] x19: ffff1321c6964680 x18: 0000000000000000
[ 17.161158] x17: 0000000000000000 x16: 0000000000000000
[ 17.166619] x15: 000000000000014a x14: 0000000000000a98
[ 17.172080] x13: 0000000000000a98 x12: 0000000000000018
[ 17.177541] x11: ffff1328ec4c0f40 x10: 0000000000000a80
[ 17.183002] x9 : ffff80001276bce0 x8 : ffff1321c66761e0
[ 17.188466] x7 : 0000000000000020 x6 : 0000000000000000
[ 17.193928] x5 : 00000000410fd420 x4 : 0000000000f0000f
[ 17.199390] x3 : 0000000000000000 x2 : 0000000000000001
[ 17.204853] x1 : 0000000000000000 x0 : 0000000000000000
[ 17.210319] Call trace:
[ 17.212830] tegra_qspi_isr_thread+0x15c/0x330
[ 17.217402] irq_thread_fn+0x34/0xa0
[ 17.221080] irq_thread+0x158/0x250
[ 17.224673] kthread+0x148/0x168
[ 17.227999] ret_from_fork+0x10/0x1c
[ 17.231681] Code: b9407660 f240003f 1a941000 b9005a60 (b94012a2)
[ 17.237963] ---[ end trace 4c40a45366b8047c ]---
[ 17.242717] Kernel panic - not syncing: Oops: Fatal exception
[ 17.248621] SMP: stopping secondary CPUs
[ 17.252659] Kernel Offset: 0x4686a5c10000 from 0xffff800010000000
[ 17.258923] PHYS_OFFSET: 0xffffecdf40000000
[ 17.263227] CPU features: 0x0040006,4a80aa38
[ 17.267624] Memory Limit: none
[ 17.270761] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
Here is the entire console log prior to the kernel panic:
orin-tegra_qspi_isr_thread_kernel_panic_log.txt (60.4 KB)
