We’re trying to flash the Orin Nano (4GB SOM w/ external NVME drive) using this command:
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_external.xml \
-p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
--showlogs --network usb0 jetson-orin-nano-devkit internal
During the flashing, we see errors like this (1):
[ 7]: l4t_flash_from_kernel: Starting to flash to qspi
mtd_debug: error!: open()
And then later this (2):
[ 335]: l4t_flash_from_kernel: Successfully flash the external device
[ 335]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
[ 335]: l4t_flash_from_kernel: Error flashing qspi
Flash failure
Cleaning up...
Can you please tell me how to debug this issue with the qspi? It seems the NVME can be flashed successfully, but not the memory on the SOM.
I’ve also attached the whole log file here:
5-3-2023-flash.log (284.7 KB)
