I received a shipment of new Orin Nano SOMs that contain GigaDevice QSPI ROM (as part of PCN214041).
https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v5.0/t234-pcn214041-qspi-35.5.0.tbz2
We are running L4T 35.5.0, and I have received overlay files from PCN Center.
I applied these overlay files, but additionally we want to burn software fuses on these new SOMs as well:
sudo ./odmfuse.sh -i 0x23 -k rsa.pem -S sbk.key -X fuse.xml jetson-orin-nano-devkit
Unfortunately when I run odmfuse.sh, the process is stuck indefinitely, and I can see “Busy spin” errors in the UART logs. I have attached both logs on this ticket.
Is there anything that I am missing?
10-19-2026_terminal-logs.txt (11.2 KB)
10-19-2026_uart-logs.txt (4.5 KB)
More specifically, the odmfuse process is stuck on “tegrarcm_v2 --chip 0x23 0 --ismb2applet” and I can see these errors in the UART logs:
I> Applet (version: 0.0.0.0-t234-54845784-d30edb11)
I> t234-A01-1-Silicon (0x12347)
I> Emulation:
I> Entry timestamp: 0xffffffff
I> Task: Pinmux init (0x4000062d)
I> Task: Boot device init (0x40001321)
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
E> SPI_FLASH: Invalid value device id: 8.
E> Failed to open qspi flash=0, err = 3c3c0902
E> Failed to initialize boot device
C> Applet storage init failed
C> Task 0x0 failed (err: 0x3c3c0902)
E> Top caller module: SPI_FLASH, error module: SPI_FLASH, reason: 0x02, aux_inf9
I> Busy Spin
hello kevin.choi,
let’s have issue narrow down, please check you’ve updated applet (i.e. applet_t234.bin) correctly.
to be more specific, you should replace below for this PCN update, you’ll need to perform a full flash to have confirmation.
$OUT/Linux_for_Tegra/bootloader/applet_t234.bin
$OUT/Linux_for_Tegra/bootloader/mb2_t234.bin
please refer to Jetson Orin Series Modules Fuse Update Field Services Bulletin regrading to fuse burning,
as you can see.. the fuse value for boot_security_info was burned (by manufacturing) to 0x1E0.
you must have bitwise logically OR with the desired value with 0x1E0 in the fuse programming flow.
Yes, I can see that these files have been added in successfully.
hello kevin.choi,
kevin.choi:
fuse.xml
let’s examine your fuse burning process.
please share the key combination you’ve enabled, you may omit the key values for security concerns.
Here is an edited copy of fuse.xml:
cat fuse.xml
<genericfuse MagicId="0x45535546" version="1.0.0">
<fuse name="PublicKeyHash" size="64" value="$PUBLIC_KEY_HASH"/>
<fuse name="SecureBootKey" size="32" value="$SECURE_BOOT_KEY"/>
<fuse name="OemK2" size="32" value="$KEK_K2_KEY"/>
<fuse name="BootSecurityInfo" size="4" value="0x3e9"/>
<fuse name="SecurityMode" size="4" value="0x1"/>
</genericfuse>
Here are also the ways we have created the keys:
# Get PKC
openssl genrsa -out rsa.pem 3072 \
PUBLIC_KEY_HASH=$(./bootloader/tegrasign_v3.py \
--pubkeyhash rsa.pubkey rsa.hash --key rsa.pem | \
grep "tegra-fuse format" | awk '{print $NF}')
# Get SBK
SBK_0=$(openssl rand -hex 4)
SBK_1=$(openssl rand -hex 4)
SBK_2=$(openssl rand -hex 4)
SBK_3=$(openssl rand -hex 4)
SBK_4=$(openssl rand -hex 4)
SBK_5=$(openssl rand -hex 4)
SBK_6=$(openssl rand -hex 4)
SBK_7=$(openssl rand -hex 4)
SBK_KEY=$(echo "0x${SBK_0} 0x${SBK_1} 0x${SBK_2} 0x${SBK_3} 0x${SBK_4} 0x${SBK_5} 0x${SBK_6} 0x${SBK_7}")
echo "${SBK_KEY}" > sbk.key
SECURE_BOOT_KEY="0x${SBK_0}${SBK_1}${SBK_2}${SBK_3}${SBK_4}${SBK_5}${SBK_6}${SBK_7}"
# Get KEK
KEK_2_0=$(openssl rand -hex 4)
KEK_2_1=$(openssl rand -hex 4)
KEK_2_2=$(openssl rand -hex 4)
KEK_2_3=$(openssl rand -hex 4)
KEK_2_4=$(openssl rand -hex 4)
KEK_2_5=$(openssl rand -hex 4)
KEK_2_6=$(openssl rand -hex 4)
KEK_2_7=$(openssl rand -hex 4)
KEK_2_KEY=$(echo "0x${KEK_2_0} 0x${KEK_2_1} 0x${KEK_2_2} 0x${KEK_2_3} 0x${KEK_2_4} 0x${KEK_2_5} 0x${KEK_2_6} 0x${KEK_2_7}")
echo "${KEK_2_KEY}" > kek.key
KEK_2_KEY="0x${KEK_2_0}${KEK_2_1}${KEK_2_2}${KEK_2_3}${KEK_2_4}${KEK_2_5}${KEK _2_6}${KEK_2_7}"
hello kevin.choi,
is this target fused before?
the root-of-trust that uses the NVIDIA SoCs fuses to authenticate boot codes ends at the Bootloader.
it’s PKC and SBK keys for authenticate; let’s double check if you can run flash script to re-flash this target with the same PKC/SBK key.
please sharing the logs from the host/target side as well.
kayccc
November 11, 2026, 2:38am
10
