Hi there,
I’m running L4T 36.5, which was downloaded through SDK manager. I cannot find the following file referenced in the guide:
“tegra234-dcb-p3701-0000-a02-p3737-0000-a01.dtsi”,
Any guidance will be greatly appreciated.
Hi there,
Unfortunately, the provided context does not mention the file “tegra234dcbp37010000a02p37370000a01.dtsi” or any related information. However, I can try to provide some general guidance on how to proceed.
The file “tegra234dcbp37010000a02p37370000a01.dtsi” seems to be a device tree source file, which is used to describe the hardware components of the Jetson AGX Orin module. These files are typically used during the boot process to configure the hardware.
Here are a few possible steps you can take to resolve the issue:
find command in Linux to search for the file.In comparison to the provided context, the issue you are facing seems to be unrelated to the flashing process described in the context. The context provides information on how to flash the Jetson AGX Orin module using the l4t_initrd_flash.sh script, but it does not mention the file “tegra234dcbp37010000a02p37370000a01.dtsi” or any related issues.
Source code could be downloaded from the l4t archive website.
Please give more guidance. Is there not any file I can decompile and edit - something about the dcb tool?
after you download the source code, you could see the file “tegra234-dcb-p3701-0000-a02-p3737-0000-a01.dtsi”.
Running dcb tool on it will give you a result with human readable result. And you could configure it with this human readable result ( i.e. enable HDMI on it).
After that, you need to build the whole kernel dtb by following the documentation.
I downloaded the source code and a folder called “public_sources.tbz2” was downloaded. I dont see it containing any .dtsi, unless I have to extract further into it. I extracted the kernel and display driver souce, but couldnt find the file in there.
I did find the following: “tegra234-dcb-p3737-0000-p3701-0000.dtsi”
Kindly advise if this is correct
You could extract all of them and it will definitely have the dts file you need.
The directory “hardware” will have them.
I still havent found that file name, but im using the file i did find: tegra234-dcb-p3737-0000-p3701-0000.dtsi
During the building phase of the new kernel, how do i include this new modified .dtsi file - since i didnt have the dtsi file initially? Where is it referenced?
Im also a little confused. The carrier Im using is based of the seed studios schematic, which takes the hdmi/dp output and just routes it to an HDMI port. Besides pinmux, do i really need to change the device tree? I see that the tegra234-dcb-p3737-0000-p3701-0000.dtsi had enabled the dp and hdmi.
will create a new thread because im trying to solve a seperate issue with this.
What does that mean “I still havent found that file name, but im using the file i did find: tegra234-dcb-p3737-0000-p3701-0000.dtsi”?
So where did you get this file?
Orin AGX only has one display output. So it could be either DP or HDMI. There is nothing called “enable DP and HDMI”. These 2 items could not be enabled at same time.
Please be aware that you are not the first one who ever meets these questions before. Just follow what we suggest.
please check the kernel oot modules tarball in the source. It has the device tree.
it was the only file i could find, without having to extract every single tarball. This is where it was: Linux_for_Tegra/source/hardware/nvidia/t23x/nv-public/nv-platform. Kindly advise if this file will work at all?
Yes, that file in that location is the correct one.
Please advise where in the code it tegra234-dcb-p3737-0000-p3701-0000.dtsi is included, so i know what to extract, where to replace the file and then what to recompile.
Check what is the file in use on your Jetson /boot/dtb directory.
That one without “kernel” perfix would be the final dtb you should replace in your BSP folder.
Already told how to compile it in
I see here, while configuring the dcb file, that it default has dp on [0], and TMDS on [1]:
########### Display Devices #############
Display Devices::
Display Devices : [0]
Type : [DP]
CCB : [0]
Heads : 0:[Y] 1:[Y]
Sor : [0 ]
DP Lane Count : [4]
DP Link Rate : [8.1GHz]
External Link Type : DP
Connector : [0]
Bus : [0]
Display Devices : [1]
Type : [TMDS]
CCB : [0]
Heads : 0:[Y] 1:[Y]
Sor : [0 ]
HDMI capable : [1]
Connector : [0]
Bus : [0]
is there any reason to reconfigure? This was the dp and hdmi configuration i was referring to.
Please directly use this hardware/nvidia/t23x/nv-public/overlay/tegra234-dcb-p3767-0000-hdmi.dts file to replace your dcb content. This one has HDMI enabled.
This kind of duplicated HDMI+ DP configuration on same connector won’t work with HDMI connector.
Thanks, this was already in my existing kernel. Linux_for_Tegra/kernel/dtb/tegra234-dcb-p3767-0000-hdmi.dtbo. How can i ensure its being pointed to.
I’m still trying to find what file the kernel is using, im struggling to get setup on the jetson after flashing. Its just hanging on the installationg screen, while finding installation to copy. Will try figure that out now…
also, p3767 is not for the JAO? Please confirm this so there is no confusion.
What I want to say is you could copy just the content from the source code to your tegra234-dcb-p3737-0000-p3701-0000.dtsi.
3767 is for Orin Nano. But the content is compatible for both Orin AGX and Orin Nano
ls /boot/dtb/
kernel_tegra234-p3737-0000+p3701-0005-nv.dtb
