Hello there,
When you first flash a new device, you have to go through a system configuration process.
Is it possible to automate this step?
Thanks,
chh
Hello there,
Thanks,
chh
Hi chh,
Are you using the devkit or custom board for Xavier NX?
Are you using SDK Manager or flash script to flash your board?
For SDK Manager, you could pre-config the related username/password before flash.
For flash script, you could refer to the instruction to skip oem-config.
Hi KevinFFF,
Thanks for linking me those instructions.
They have solved my problem
