Setup:
- Jetson AGX Orin devkit
- Jetson Linux (L4T) R36.4.4
- Host: Ubuntu, x86_64 workstation (bare metal, confirmed via
systemd-detect-virt)
Command run:
sudo ./tools/backup_restore/l4t_backup_restore.sh -e mmcblk0 -b jetson-agx-orin-devkit
Symptom:
The device boots into the initrd network-flash environment successfully every time — RCM boot completes, the initrd’s USB gadget (RNDIS) network interface comes up, and the script’s own SSH-readiness check (a simple ssh ... true) succeeds, printing:
Device has booted into initrd. You can ssh to the target by the command:
$ ssh root@fc00:1:1:0::2
Immediately after, the script issues the actual backup command over a second SSH connection:
mount -o nolock [fc00:1:1::1]:.../tools/backup_restore /mnt && /mnt/nvbackup_partitions.sh -e mmcblk0 -n && echo Backup image is stored in ...
This second SSH invocation returns quickly with exit code 255 (confirmed by instrumenting l4t_backup_restore.sh to capture the real exit status) and produces zero output — no error message on stdout or stderr, nothing from the remote command, no images/ directory ever created.
backup17.log (105.7 KB)
What’s confirmed via packet capture and serial (UART) console:
- Every SYN packet from host to target during connection attempts is answered with an immediate TCP RST from the target when this fails, while ICMPv6 to the same address keeps working — so the network path itself is healthy; something specifically about port 22 / the second SSH session is being refused.
- Serial console on the target shows completely healthy boot — no kernel panic, no OOM, no Oops — right up through USB gadget networking coming up.
What I’ve ruled out:
- Host firewall / iptables / ip6tables / nftables / ufw / Docker network rules — all clean
- NFS export configuration/permissions — confirmed correct and present at the exact moment of the mount attempt
- rpcbind/portmapper — running correctly, responds properly over IPv6
- Missing sshd/host keys in the target’s initrd ramdisk — confirmed present in the extracted
recovery.imgramdisk - udisks2 automount interference — stopped per documented requirements, no change
- Board/BSP-specific issue — ruled out by cross-testing: this exact devkit works fine from a different host machine; a different board exhibits the identical failure on this host. So it’s host-specific, not board-specific.
- Kernel Image/DTB corruption — verified intact
- VM/USB-passthrough issues — this host is bare metal
Open question: what would cause a second SSH connection to the same target, moments after a first one succeeded, to fail with exit 255 and zero diagnostic output — especially given this is reproducible on one specific host but not on another host with the same board?
Has anyone seen this specific failure mode before, or does the initrd’s sshd have any known single-connection or rate-limiting behavior that could explain a second connection being refused right after the first one succeeds?
