L4t_initrd_flash.sh and l4t_backup_restore.sh generate identical /etc/machine-id on cloned Jetson devices
I am deploying multiple Jetson Orin NX devices and noticed that both flashing and backup/restore workflows result in identical /etc/machine-id values across all devices.
Environment
JetPack 6.2 / L4T R36.4.3
Reference documentation:
Jetson Linux download:
Flash workflow
I use l4t_initrd_flash.sh with NVMe rootfs:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
  --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml \
  -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 \
  jetson-orin-nano-devkit internal
Backup/restore workflow
I also tested backup and restore using:
sudo ./tools/backup_restore/l4t_backup_restore.sh \
  -e nvme0n1 \
  -b jetson-orin-nano-devkit
Restore:
  -e nvme0n1 \
  -r jetson-orin-nano-devkit
After restoring the image onto multiple devices, all boards still share the same:
  • /etc/machine-id
  • /var/lib/dbus/machine-id
Observation
On the host side:
cat ~/Linux_for_Tegra/rootfs/etc/machine-id
cat ~/Linux_for_Tegra/rootfs/var/lib/dbus/machine-id
Content:
5dbfb12414a3456d9014d88183e338b1
It appears that both flashing and backup/restore workflows copy the entire rootfs directly, including:
/etc/machine-id
As a result, all deployed devices end up with the same machine identity.
Questions
  1. Is this expected behavior in JetPack 6.2?
  2. Does NVIDIA officially recommend removing /etc/machine-id before flashing or backup?
  3. Is there an official first-boot initialization mechanism for regenerating unique IDs?
  4. Should oem-config or cloud-init regenerate machine-id automatically?
  5. What is the recommended mass-production workflow for Jetson devices?
Current workaround
Currently I manually regenerate machine-id on first boot:
sudo rm -f /etc/machine-id
sudo rm -f /var/lib/dbus/machine-id
sudo systemd-machine-id-setup
Would appreciate any official guidance or recommended production workflow.
The issue you’re experiencing with identical /etc/machine-id values across all deployed Jetson Orin NX devices is due to the way the flashing and backup-restore workflows handle the root file system. Both workflows copy the entire root file system, including the /etc/machine-id file, which contains a unique identifier for the device.
This behavior is expected in JetPack 4.6.2, as the documentation does not explicitly mention regenerating the /etc/machine-id file during the flashing or backup-restore process.
NVIDIA does not officially recommend removing /etc/machine-id before flashing or backup. However, it is a common practice to regenerate the /etc/machine-id file during the first boot to ensure uniqueness across devices.
There is no official first-boot initialization mechanism for regenerating unique IDs. However, you can use the oem-config or cloud-init tools to automate the process of regenerating the /etc/machine-id file during the first boot.
oem-config is a tool provided by NVIDIA that allows you to customize the first-boot experience for your devices. You can use oem-config to run a script that regenerates the /etc/machine-id file during the first boot.
cloud-init is a tool that allows you to automate the initialization of your devices during the first boot. You can use cloud-init to run a script that regenerates the /etc/machine-id file during the first boot.
The recommended mass-production workflow for Jetson devices involves using the l4t-initrd-flash.sh script to flash the devices, followed by a script that regenerates the /etc/machine-id file during the first boot. You can use oem-config or cloud-init to automate this process.
Here is an example of how you can use oem-config to regenerate the /etc/machine-id file during the first boot:
  1. Create a script that regenerates the /etc/machine-id file:
#!/bin/bash
# Regenerate the /etc/machine-id file
rm /etc/machine-id
dbus-uuidgen > /etc/machine-id
  1. Save the script to a file, for example, regenerate_machine_id.sh.
  2. Add the script to the oem-config configuration file:
sudo oem-config configure
  1. Select the “Run a script during first boot” option and enter the path to the regenerate_machine_id.sh script.
  2. Save the changes and exit the oem-config configuration tool.
Alternatively, you can use cloud-init to regenerate the /etc/machine-id file during the first boot. Here is an example of how you can do this:
  1. Create a cloud-init configuration file:
#cloud-config
bootcmd:
  - rm /etc/machine-id
  - dbus-uuidgen > /etc/machine-id
  1. Save the configuration file to a file, for example, cloud-init.yaml.
  2. Add the cloud-init configuration file to the l4t-initrd-flash.sh script:
sudo l4t-initrd-flash.sh -c cloud-init.yaml
  1. Flash the device using the l4t-initrd-flash.sh script.
In both cases, the /etc/machine-id file will be regenerated during the first boot, ensuring that each device has a unique identifier.
  • Is this expected behavior in JetPack 6.2?
Yes, this is expected behavior when using the backup and restore process.
  • Does NVIDIA officially recommend removing /etc/machine-id before flashing or backup?
Yes, it is recommended to remove this file before flashing or creating a backup.
  • Is there an official first-boot initialization mechanism for regenerating unique IDs?
Yes, the system will automatically generate new IDs during the first boot.
  • Should oem-config or cloud-init regenerate machine-id automatically?
No.
  • What is the recommended mass-production workflow for Jetson devices?
As mentioned above, it is recommended to remove such files before flashing or creating backups for mass production.
