L4t_initrd_flash.sh cmd question
I see two methods as shown below for Orin NX with nvme ssd. Currently, I used method 1 and works well.
May I know what’s the meaning of parameter “–no-systemimg”, “external” vs “internal”.
1,
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/IN/QuickStart.html#to-flash-the-jetson-developer-kit-operating-software
2,
README_initrd_flash.txt
Whether you add --no-systemimg or not makes no difference because the QSPI memory itself does not contain anything about rootfs, but only bootloader stuff.
For internal vs external, it also makes no difference. There’s a chart in Workflow 3 describing the difference.
| --external-device |       <rootdev> | Results                                               |
| nvme*n*p* / sda*  |        internal | External device contains full root filesystem with    |
|                   |                 | kernel commandline: rootfs=PARTUUID=<external-uuid>   |
|                   |                 | Internal device contains full root filesystem with    |
|                   |                 | kernel commandline: rootfs=PARTUUID=<internal-uuid>   |
| nvme*n*p* / sda*  | nvme0n*p* / sd* | External device  contains full root filesystem with   |
|                   |                 | with kernel commandline rootfs=/dev/nvme0n1p1         |
|                   |                 | Internal device contains minimal filesystem with     |
|                   |                 | kernel command line rootfs=/dev/nvme0n1p1             |
| nvme*n*p* / sda*  |       mmcblk0p1 | External device  contains full root filesystem with   |
|                   |                 | Internal device contains full filesystem with     |
|                   |                 | kernel command line rootfs=/dev/mmcblk0p1             |
| nvme*n*p* / sda*  |        external | External device contains full root filesystem with    |
|                   |                 | Internal device contains minimal root filesystem with |
As you don’t have an internal storage device (eMMC/SD card) with Orin NX, internal/external means the same.
ok, thanks for explanation.
