I came across an annoying kernel bug/issue handling the sensor modes pixelformats.
The pixel format of a sensor is defined in the “pixel_t” property of the mode specification in the device tree. The format defined there is parsed by the “extract_pixel_format” function in sensor_common.c. Most (if not all) sensor dtsi files of the l4t kernel specify “bayer_rggb” for the “pixel_t” property but this pixel format is not one of the ones that “extract_pixel_format” checks for:
static int extract_pixel_format(
const char *pixel_t, u32 *format)
size_t size = strnlen(pixel_t, OF_MAX_STR_LEN);
if (strncmp(pixel_t, "bayer_bggr10", size) == 0)
*format = V4L2_PIX_FMT_SBGGR10;
else if (strncmp(pixel_t, "bayer_rggb10", size) == 0)
*format = V4L2_PIX_FMT_SRGGB10;
else if (strncmp(pixel_t, "bayer_grbg10", size) == 0)
*format = V4L2_PIX_FMT_SGRBG10;
else if (strncmp(pixel_t, "bayer_bggr12", size) == 0)
*format = V4L2_PIX_FMT_SBGGR12;
else if (strncmp(pixel_t, "bayer_rggb12", size) == 0)
*format = V4L2_PIX_FMT_SRGGB12;
else if (strncmp(pixel_t, "bayer_wdr_pwl_rggb12", size) == 0)
else if (strncmp(pixel_t, "bayer_wdr_dol_rggb10", size) == 0)
else if (strncmp(pixel_t, "bayer_xbggr10p", size) == 0)
*format = V4L2_PIX_FMT_XBGGR10P;
else if (strncmp(pixel_t, "bayer_xrggb10p", size) == 0)
*format = V4L2_PIX_FMT_XRGGB10P;
else {
pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
return -EINVAL;
return 0;
It is only for the reason that the function uses “strncmp” to compare the strings that the “bayer_rggb” string most drivers use, the string matches the first occurrence in the function. This is the 10 bit version of the pixel format, unless a future version of this function happens to have a different order of strings. With a 12 bit sensor this returns an incorrect pixel format, leading to an error in the capture process.
In my opinion, the “bayer_rggb” string for pixel_t should either be rejected in the “extract_pixel_format” function or it should be explicitly documented as a 10 bit format and handled as such. Right now, if you specify “bayer_rggb” for a 12 bit sensor, it will just silently fail without a real clue of what is going on.
