L4T Multimedia API dependency
is there a special dependency or L4T configurations on libargus? I use a std. L4T installation from nvidiasdk manager and sometimes the stream breaks with this fault.
We use Jetpack 4.2.2.
Thanks for your help
It looks to be instability of the camera source. Do you run the default camera board ov5693 or camera board from other vendors?
Its our own carrier board with cameras from an other vendor. Is there an main documentation for such errors?
Sorry to tell there’s no document for this kind of problem. However you can reference to below wiki link to get some information.
What’s the sensor configure? Have a check if sensor output stable by v4l2-ctl command.
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1000
https://elinux.org/Jetson_TX2_Camera_BringUp
