I’m using L4T 32.3.1. By modifying Multimedia API sample 02_video_dec_cuda, I was able to scale 1920x1080 h264 video into 1280x720 ARGB32 data.
Howerer, it keep showing logs like:
libv4l2_nvvidconv (0):(1548) (INFO) : Stitch rect’s right out of boundary, set to MAXlibv4l2_nvvidconv (0):(1553) (INFO) : Stitch rect’s bottom out of boundary, set to MAXconv decconv cap
My question is: What does it means? And can I disable this log?
Please share a patch on 02_video_dec_cuda so that we can reproduce the problematic prints.
I only modified jetson_multimedia_api/samples/02_video_dec_cuda/videodec_main.cpp at line 618
In Function query_and_set_capture :
// ret = ctx->conv->setCapturePlaneFormat((ctx->out_pixfmt == 1 ?
// V4L2_PIX_FMT_NV12M :
// V4L2_PIX_FMT_YUV420M),
// crop.c.width,
// crop.c.height,
// V4L2_NV_BUFFER_LAYOUT_PITCH);
// if (ctx->enable_osd_text)
// cout<<" Text overlay can only work with ABGR format, set converter capture plane to ABGR" <<endl;
// ret = ctx->conv->setCapturePlaneFormat(V4L2_PIX_FMT_ABGR32,
// crop.c.width,
// crop.c.height,
1280,
720,
You also need to set destination resolution to 1280x720.
ret = ctx->conv->setDestRect(0, 0, 1280/*crop.c.width*/, 720/*crop.c.height*/);
Yes, it solve my problem, thanks!!!
