Hi all,
Is it possible to change, on the fly, the number of csi input lanes used?
Use case example:
Step 1- TX2 acquiring 1920x1080p25 video over 2-lane MIPI CSI.
Step 2- User send command to change input resolution acquisition to NTSC(720x480i60).
Step 3- TX2 reconfiguring itself (kernel driver or user space command) to aquire 720x480i60 video 1-lane MIPI CSI.
For 1920x1080p25 2-lane input, the csi configuration is set in device-tree like this:
host1x {
vi@15700000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
csiconv_vi_in0: endpoint {
status = "okay";
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&csiconv_csi_out0>;
nvcsi@150c0000 {
num-channels = <2>;
#size-cells = <0>;
channel@0 {
status = "okay";
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
csiconv_csi_in0: endpoint@0 {
status = "okay";
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&csiconv_out0>;
port@1 {
status = "okay";
reg = <1>;
csiconv_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&csiconv_vi_in0>;
i2c@3180000 {
status = "okay";
#size-cells = <0>;
/* First input */
csiconv@70 {
status = "okay";
compatible = "csiconv";
reg = <0x70>;
devnode = "video0";
mode0 {
num_lanes = "2";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "16";
csi_pixel_bit_depth = "16";
mode_type = "yuv";
pixel_phase = "uyvy";
active_w = "1920";
active_h = "1080";
readout_orientation = "0";
line_length = "2200";
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
csiconv_out0: endpoint {
csi-port = <0>;
bus-width = <2>;
remote-endpoint = <&csiconv_csi_in0>;
tcp: tegra-camera-platform {
status = "okay";
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <12>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <8>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <408000>;
isp_peak_byte_per_pixel = <2>;
isp_bw_margin_pct = <25>;
modules {
module0 {
status = "okay";
badge = "csiconv_left_1111";
position = "rear";
orientation = "1";
drivernode0 {
status = "okay";
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver's v4l2 device name */
devname = "csiconv 2-0070";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/csiconv_ef@70";
I have looked different drivers/device-tree with several modes (mode0, mode1, etc.) but each mode have same number of lane.
From the device side, I have already implement methods to switch between 1, 2 and 4 lanes configuration.
My problem/question is about the capability of TX2 to reconfigure the lane number.
Q1 - First of all, is it possible?
Q2 - Is there an example? What is the tasks sequencing (reset DPHY, then NVCSI, etc.)?
Q3 - I think I should reconfigure or reset NVCSI and VI with the new parameters. How can I achieve this?
Q4 - How to send new parameters to NVCSI and VI?
PS: It’s acceptable to have a video interruption during reconfiguration but I want to avoid TX2 restarting.
