L4T R38.4.0: initrd flash fails on jetson-orin-nano-devkit-super — dtbcheck.py not copied to staging directory
Summary
Flashing a Jetson Orin Nano Super devkit using l4t_initrd_flash.sh with L4T R38.4.0 fails with:
Error: Unexpected error in updating: tegra234-bpmp-3767-0003-3768-super_with_odm.dtb
The root cause is that copy_bootloader() in l4t_initrd_flash_internal.sh does not copy dtbcheck.py to the temporary staging directory. When tegraflash_impl_t264.py later checks for the file with os.path.exists('dtbcheck.py'), it doesn’t find it and raises an exception.
Environment
- Host: Ubuntu 24.04 x86_64
- BSP: L4T R38.4.0 (JetPack 7.1)
- Board: jetson-orin-nano-devkit-super
- Flash method: initrd flash to NVMe
Flash command used
cd Linux_for_Tegra
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
--external-device nvme0n1p1 \
-c tools/kernel_flash/flash_l4t_t234_nvme.xml \
-p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
--showlogs \
--network usb0 \
jetson-orin-nano-devkit-super internal
Full error output
Bootloader is not running
Parsing partition layout
tegraparser_v2 --pt flash_l4t_t234_nvme_uda_only.xml.tmp flash_t234_qspi.xml.tmp
Successfully read partition layout
Updating bpmp-dtb (tegra234-bpmp-3767-0003-3768-super_with_odm.dtb)
Root cause analysis
The flash process changes its working directory to a temporary staging directory (temp_dir) during the BPMP DTB update phase. In tegraflash_impl_t264.py (around line 2167), the code checks:
tmp_dtb = tegraflash_create_backup_file(bpmp_dtb, '_tmp')
if os.path.exists(tmp_dtb) and os.path.exists('dtbcheck.py'):
# run dtbcheck validation...
else:
raise tegraflash_exception('Unexpected error in updating: ' + bpmp_dtb + ' ')
The tmp_dtb file exists, but dtbcheck.py does not because copy_bootloader() in tools/kernel_flash l4t_initrd_flash_internal.sh never copies it to the staging directory. The function copies tegraflash*.py, tegrasign*.py, and pyfdt, but omits dtbcheck.py.
This appears to affect only the “super” board variant (jetson-orin-nano-devkit-super), which uses the tegra234-bpmp-3767-0003-3768-super_with_odm.dtb BPMP DTB that triggers the dtbcheck.py code path.
Fix
Add a conditional copy of dtbcheck.py to the copy_bootloader() function in tools/kernel_flash/l4t_initrd_flash_internal.sh:
--- a/tools/kernel_flash/l4t_initrd_flash_internal.sh
+++ b/tools/kernel_flash/l4t_initrd_flash_internal.sh
@@ -800,6 +800,9 @@
cp tegraparser_v2 "${temp_bootloader}";
cp tegrarcm_v2 "${temp_bootloader}";
cp -r -t "${temp_bootloader}" ./tegraflash*.py ./tegrasign*.py ./pyfdt
+ if [ -f dtbcheck.py ]; then
+ cp dtbcheck.py "${temp_bootloader}";
+ fi;
cp tegraopenssl "${temp_bootloader}";
After applying this patch, the flash completes successfully and the Jetson boots normally.
Steps to reproduce
- Download L4T R38.4.0 BSP and rootfs from NVIDIA
- Extract and run apply_binaries.sh
- Connect a Jetson Orin Nano Super in recovery mode via USB-C
- Run the flash command above
- Observe the dtbcheck.py error
