Lab Launch Issue - Time Limit Exceeded - [Getting Started with Deep Learning]
Hello DLI Support Team,
I am currently stuck and unable to launch my lab workspace for the course “Getting Started with Deep Learning”. The webpage hangs/spins infinitely, and I believe I have accidentally exhausted my allocated time limit while working toward the final assessment.
I have already attempted basic troubleshooting (clearing browser cache, trying Google Chrome Incognito mode, and checking my network WebSocket connection), but the lab still fails to load.
Could an administrator please check my instance, reset my lab session, or extend my allocated lab hours so that I can finish and submit my assessment?
  • Course Name: Getting Started with Deep Learning
  • Registered Account Email: ******
Thank you for your assistance!
To get started with TensorRT for deep learning, you’ll need to follow these steps:
  1. Install TensorRT: You can install TensorRT using the command provided in the documentation. Make sure to add the “deb” repository as mentioned in the CUDA Toolkit installation step.
  2. Choose a Sample: Start with the “Hello World” sample for TensorRT from ONNX, which converts a model trained on the MNIST dataset in ONNX format to a TensorRT network and runs inference on the network.
  3. Understand TensorRT’s Capabilities: Familiarize yourself with TensorRT’s capabilities, including dynamic range information, tensors, and data formats. TensorRT assumes that tensors are represented by multidimensional C-style arrays, and each layer has a specific interpretation of its inputs.
  4. Explore the API Reference: The TensorRT API Reference provides detailed information on the various classes, functions, and parameters available in TensorRT. This will help you understand how to use TensorRT for your deep learning applications.
  5. Integrate with Other NVIDIA Tools: TensorRT can be integrated with other NVIDIA tools, such as NVIDIA DALI for preprocessing image, audio, and video data, and NVIDIA Triton Inference Server for optimized inference across CPUs and GPUs.
  6. Optimize Memory Allocation: By default, TensorRT allocates device memory directly from CUDA. However, you can attach an implementation of TensorRT’s IGpuAllocator interface to the builder or runtime and manage device memory yourself.
  7. Control Dependencies: TensorRT’s dependencies, such as NVIDIA cuDNN and NVIDIA cuBLAS, can occupy large amounts of device memory. You can control whether these libraries are used for inference by using the TacticSources attribute in the builder configuration.
Comparison with Other Frameworks:
TensorRT is designed to work in a complementary fashion with training frameworks such as TensorFlow, PyTorch, and MXNet. It focuses specifically on running an already-trained network quickly and efficiently on NVIDIA hardware.
In comparison to TensorFlow-TensorRT (TF-TRT), which integrates TensorRT directly into TensorFlow, TensorRT provides a more flexible and customizable solution for optimizing deep learning inference.
Key Benefits:
  • High-performance deep learning inference
  • Support for various NVIDIA hardware platforms
  • Flexible and customizable solution for optimizing deep learning inference
  • Integration with other NVIDIA tools for preprocessing and inference
By following these steps and understanding the capabilities and benefits of TensorRT, you can get started with using TensorRT for your deep learning applications.
Hi @prashant_btech25, thanks for laying out what you’ve already tried.
Two quick things up front. This is a Deep Learning Institute (DLI) course/lab issue rather than a TensorRT one, so it’s landed in the wrong category. And the automated reply just above yours is an LLM triage pass that’s off the mark here: it printed generic TensorRT install steps that have nothing to do with your lab failing to launch, so you can safely ignore it.
For a lab workspace that won’t load and a time limit that needs resetting, the forum can’t act on your account; that has to go through DLI support. Everything you need is on one page:
  • Open a support case from the email enrolled in the course, and include the course name plus a screenshot of the spinning page. That’s the team that can reset your lab session or extend your hours.
  • The Technical Support section on that same page also has a self-check for the exact “GPU instance won’t launch” symptom. It walks you through a websockets connectivity test and notes that only Chrome and Firefox are supported, so trying a different browser or network can get you unblocked while the case is open.
I’m moving this thread over to Learning and Certification > Courses and Workshops so the training team sees it in their queue:
⚠️ One heads-up: your post includes your account email in the clear. I’d edit that out; a public forum thread isn’t the place for it, and the support case is where it belongs.
Thanks,
Atharva
