I tested the routine of target detection in deepstream SDK 4.0。For example, the labels of object Detector_SSD and object Detector_Yolo targets are in English. If I want to change them into Chinese, how can modify them?
You can follow the standard Ubuntu setting to install Chinese input.
Here is a tutorial for your reference: Ubuntu 16.04 安装中文输入法(Ubuntu 16.04 install chinese input method)_星河_SR的博客-CSDN博客
System Settings–> Language Support–> Install/Remove Languages → Choose the language you need.
