LAG, Lacp configuration on Mellanox switches
Following the user manual of mlnx_os 3.4.0012 these are the instructions for enabling lacp:
Step 1. Log in as admin.
Step 2. Enter config mode. Run:
Step 3. Create a port-channel entity. Run:
Step 4. Change back to config mode. Run:
switch > enable
switch # configure terminal
switch (config) # interface port-channel 1
switch (config interface port-channel 1) #
switch (config interface port-channel 1) # exit
switch (config) #
switch (config interface ethernet 1/4) # channel-group 1 mode on
If the physical port is operationally up, this port becomes an active member of the
aggregation. Consequently, it becomes able to convey traffic.
switch > enable
switch (config) #
Rev 3.30
Mellanox Technologies 480
Mellanox Technologies Confidential
Step 5. Enable LACP in the switch. Run:
Step 6. Add a physical port to the port-channel. Run:
switch (config) # lacp
switch (config) #
switch (config interface ethernet 1/4) # channel-group 1 mode active/passive
Running it in lab I get the following:
(port channel 1 is already configured)
sx6036-gso [standalone: master] (config interface ethernet 1/23) # channel-group 1 mode active
% Cannot add Interface Eth1/23 with channel-group mode (active) to channel-group 1 mode (on) - Incompatible mode
sx6036-gso [standalone: master] (config interface ethernet 1/23) # channel-group 1 mode passive
% Cannot add Interface Eth1/23 with channel-group mode (passive) to channel-group 1 mode (on) - Incompatible mode
Any idea why?
Thanks,
Einav.
Can you send the running config. it looks like there is another port attached to this LAG that was configured with mode on (static LAG), you can not add a second port to a LAG that is considered as Static.
Try removing all ports from the LAG (run: "no channel-group … " on all the ports in the LAG) and then try to run it again on port 1/23.
Ophir.
I just created another post discussing this
HowTo Configure LACP on LAG on Mellanox Switches (Old)
