I have enable its driver as a module.(CONFIG_LAN743X=m)
Driver is build successfully on my target board.
I have found .ko file on below path.
ls /home/cimcon/linux-master/drivers/net/ethernet/microchip/lan743x.ko
4)sudo insmod lan743x.ko
insmod: ERROR: could not insert module lan743x.ko: Invalid module format
5)sudo modprobe lan743x.ko
modprobe: FATAL: Module lan743x.ko not found in directory /lib/modules/4.9.253-tegra
cimcon@cimcon-nano:~/linux-master/drivers/net/ethernet/microchip$ ls /lib/modules/4.9.253-tegra/lan743x.ko
file lan743x.ko
lan743x.ko: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), BuildID[sha1]=5a7c29d8caee8e415c0926e30fb78bc9df7a7aa0, with debug_info, not stripped
