> ls -l /sys/class/backlight
lrwxrwxrwx. 1 root root 0 Aug 6 08:46 /sys/class/backlight/nvidia_0 -> ../../devices/pci0000:00/0000:00:01.0/0000:01:00.0/backlight/nvidia_0
> ls -l /sys/class/backlight/nvidia_0/
-r--r--r--. 1 root root 4096 Aug 6 08:53 actual_brightness
-rw-r--r--. 1 root root 4096 Aug 6 08:53 bl_power
-rw-r--r--. 1 root root 4096 Aug 6 08:46 brightness
lrwxrwxrwx. 1 root root 0 Aug 6 08:53 device -> ../../../0000:01:00.0
-r--r--r--. 1 root root 4096 Aug 6 08:46 max_brightness
drwxr-xr-x. 2 root root 0 Aug 6 08:53 power
-r--r--r--. 1 root root 4096 Aug 6 08:53 scale
lrwxrwxrwx. 1 root root 0 Aug 6 08:46 subsystem -> ../../../../../../class/backlight
-r--r--r--. 1 root root 4096 Aug 6 08:46 type
-rw-r--r--. 1 root root 4096 Aug 6 08:46 uevent
The backlight control still doesnāt work with nvidia-drm.modeset=1 removed from the boot parameters and the contents of /sys/class/backlight donāt change. A bug report without nvidia-drm-modeset=1 is attached. nvidia-bug-report.log.gz (1.2 MB)
Still present in 470.63.01. No backlight controls for the laptop work. Everything in /sys/class/backlight change as expected, but it never gets to the hardware.
I finally decided to go back to 460.91.03, now I have control over my screen brightness. I hoop thereās a fix soon. Itās no fun to have to wear sunglasses for your laptop.
I have a similar Clevo laptop that also has the brightness control problem. The good news is that one of my colleagues tracked it down to a new type of brightness control method used by these panels that wasnāt enabled in the Linux driver. Heās working on a fix to wire that up properly.
Can you please explain how did you install 460.91.03 Nvidia driver.
I tried by running: sudo apt install nvidia-driver-460 but I always get Nvidia 470.
I also tried downloading the driver from Nvidia website but it says that I have to unload current driver in order to install that one, but I donāt know how to do it.
I can confirm having the same issue, albeit with half the actual brightness showing as the max brightness. My laptopās backlight is stuck that way no matter what I do (the brightness controls work but donāt affect the brightness at all). I can only modify it by tweaking the colour correction parameters in the nvidia X server settings application but it doesnāt affect the actual brightness and I still canāt see anything clearly.
This issue only manifests with NVIDIA 470 drivers, the 460 driver works but crashes the X server upon waking from suspend.
Iāve tried everything from baking the nvidia-drm kernel modules into initramfs to purging every modified configuration file referencing nvidia on my system. Nothing works.
Here are my specs:
OS: Ubuntu 21.04 x86_64
Model: HP Omen 17-an000
CPU: IntelĀ® Coreā¢ i7-8750H CPU @ 2.20GHz Ć 12
GPU: NVIDIA GeForce GTX 1060 Mobile 6GB
Kernel: 5.11.0-31-generic
NVIDIA Driver Version: 470.57.02
Here are the contents of /sys/class/backlight/nvidia_0/device/backlight/nvidia_0:
drwxr-xr-x 3 root root 0 Aug 29 14:12 ./
drwxr-xr-x 3 root root 0 Aug 29 14:12 ../
-r--r--r-- 1 root root 4096 Aug 29 14:14 actual_brightness
-rw-r--r-- 1 root root 4096 Aug 29 14:14 bl_power
-rw-rw-r-- 1 root video 4096 Aug 29 14:12 brightness
lrwxrwxrwx 1 root root 0 Aug 29 14:14 device -> ../../../0000:01:00.0/
-r--r--r-- 1 root root 4096 Aug 29 14:12 max_brightness
drwxr-xr-x 2 root root 0 Aug 29 14:14 power/
-r--r--r-- 1 root root 4096 Aug 29 14:14 scale
lrwxrwxrwx 1 root root 0 Aug 29 14:12 subsystem -> ../../../../../../class/backlight/
-r--r--r-- 1 root root 4096 Aug 29 14:12 type
-rw-r--r-- 1 root root 4096 Aug 29 14:12 uevent
Hi, I have a similar laptop.
In kubuntu 21.04 with 470 driver doesnāt work but with 460 driver does. ( kernel 5.11 )
Yesterday I upgrade to kubuntu 21.10. Big mistake. It comes with kernel 5.13.0-19 and forced 470 driver.
Actually as @alenn.masic mencioned nvidia-driver-460 now is a transitional package to 470.
So I am stuck waiting a magical update.
I tried booting a kubuntu 21.10 live iso , that use the nouveau driver and doesnāt change backlight either.
In another laptop, Legion Y740 with intel i7-9750H and GeForce 2060 6GB works perfect.
Here are my specs:
OS: Kubuntu 21.10 x86_64
Model: HP Omen 17
CPU: IntelĀ® Coreā¢ i7-7700HQ CPU
Kernel: 5.13.0-19-generic
NVIDIA Driver Version: 470.74
As per @danito8905ās reply, you should purge the old NVIDIA packages before trying to install the new driver.
On my system, I purged all the old packages with the following command before I installed the new drivers: (you can remove the 470* from the command below to go for the nuclear option)
