Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
When I use the SAL layer with Entron cameras with the following parameters:
“interface=csi-gh,camera-name=F008A030BM0A_24BIT_RGGB,output-format=processed,link=1”
I see large amounts of text dumped to sample_kern.log (72.0 KB)
/var/log/kern.log
Attached are some sample outputs. The camera still works, but the hard drive eventually runs out of space. I can set up logrotate to mask the issue, but I want to know the root cause of this.
Unfortunately the issue only happens sometimes so I don’t have a way to reproduce the problem reliably. I did attach a sample of what got dumped to kern.log though so if anyone who can parse the log can provide any insight, that would be very helpful.
Yes, same issue also occurs on xavier a from time to time. we are using Sekonix cameras for xavier a. an example parameter for one of them is "interface=csi-a,camera-name=SF3324,output-format=processed,link=3"
I don’t have a kernel dump handy right now though. I can keep an eye out for when this happens next time on XavierA if you want more data
I asked because the issue had a higher reproducing rate on Xavier B when we looked into it in the other topic.
You can try if the fix helps on your problem here. Thanks.
I am able to recompile the kernel following the instructions here. It’s not entirely clear to me though how to flash the new kernel from the documentation. Do I just flash via SDK manager?. Here’s the /lib/modules after following the instructions btw:
yclin@OR-LIN-6CW:~/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/targetfs/lib/modules$ ls 4.14.150-rt67-tegra 4.14.150-tegra
the one named 4.14.150-rt67-tegra is what I built. So it looks like if I flash the targetfs verbatim, I will end up with two versions of the kernel. Is that what the depmod -a in the last step of the instructions is about?
