Large resolution sensor is not working propely.
This one has 7712x2176 resolution.
On the other hand, 3840x2160 resolution works well.
It stopped after 4 frame error output.
Is there any solution?
Plus, it works normally using this sensor on xavier. (only orin issue)
[ dts settings ]
mode0 {
mclk_khz = "25000";
num_lanes = "4";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
dynamic_pixel_bit_depth = "12";
pixel_phase = "gbrg";
active_w = "7712";
active_h = "2176";
readout_orientation = "0";
line_length = "5304";
inherent_gain = "1";
mclk_multiplier = "11";
pix_clk_hz = "365976000";
serdes_pix_clk_hz = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "300";
gain_factor = "10000";
min_gain_val = "10000";
max_gain_val = "160000";
step_gain_val = "1000";
default_gain = "10000";
framerate_factor = "1000000";
min_framerate = "30000000";
max_framerate = "30000000";
step_framerate = "1000000";
default_framerate = "30000000";
exposure_factor = "10000000";
min_exp_time = "10000000";
max_exp_time = "200000000";
step_exp_time = "10000000";
default_exp_time = "180000000";
embedded_metadata_height = "0";
[ dmesg logs ]
[ 3187.035213] DBG-MMM sam_is_write_reg:write addr 0x8b12 < val 0x100
[ 3187.035383] DBG-MMM samis_start_streaming
[ 3187.082221] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 1, flags: 0, err_data 4194400
[ 3187.116754] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 2, flags: 0, err_data 4194400
[ 3187.151284] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 3, flags: 0, err_data 4194400
[ 3187.185838] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 4, flags: 0, err_data 4194400
[ trace log ]
kworker/4:1-4007 [004] .... 3210.217377: rtcpu_nvcsi_intr: tstamp:101043384141 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217377: rtcpu_nvcsi_intr: tstamp:101043384141 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217377: rtcpu_nvcsi_intr: tstamp:101043390710 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217377: rtcpu_nvcsi_intr: tstamp:101043390710 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217377: rtcpu_nvcsi_intr: tstamp:101043399626 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217377: rtcpu_nvcsi_intr: tstamp:101043399626 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217377: rtcpu_nvcsi_intr: tstamp:101043400186 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217378: rtcpu_nvcsi_intr: tstamp:101043400186 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217378: rtcpu_nvcsi_intr: tstamp:101043400737 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217378: rtcpu_nvcsi_intr: tstamp:101043400737 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217378: rtcpu_nvcsi_intr: tstamp:101043401502 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217378: rtcpu_nvcsi_intr: tstamp:101043401502 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217378: rtcpu_nvcsi_intr: tstamp:101043422612 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217378: rtcpu_nvcsi_intr: tstamp:101043422612 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217378: rtcpu_vinotify_error: tstamp:101043449210 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:3233390273152 data:0x0000000200400060
kworker/4:1-4007 [004] .... 3210.217379: rtcpu_vinotify_event: tstamp:101043458853 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:3233390273152 data:0x0000000200400060
kworker/4:1-4007 [004] .... 3210.217379: rtcpu_nvcsi_intr: tstamp:101043504719 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217379: rtcpu_nvcsi_intr: tstamp:101043504719 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217379: rtcpu_nvcsi_intr: tstamp:101043505282 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217379: rtcpu_nvcsi_intr: tstamp:101043505282 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217379: rtcpu_nvcsi_intr: tstamp:101043507385 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217379: rtcpu_nvcsi_intr: tstamp:101043507385 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217380: rtcpu_vinotify_error: tstamp:101043509099 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:3233392139872 data:0x0000000000000589
kworker/4:1-4007 [004] .... 3210.217380: rtcpu_vinotify_event: tstamp:101043509643 cch:0 vi:0 tag:FS channel:0x00 frame:3 vi_tstamp:3233391492480 data:0x0000000300000010
kworker/4:1-4007 [004] .... 3210.217380: rtcpu_vinotify_event: tstamp:101043509775 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:3 vi_tstamp:3233392139872 data:0x0000000000000589
kworker/4:1-4007 [004] .... 3210.217380: rtcpu_nvcsi_intr: tstamp:101043510352 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217380: rtcpu_nvcsi_intr: tstamp:101043510352 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217380: rtcpu_nvcsi_intr: tstamp:101043512228 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217380: rtcpu_nvcsi_intr: tstamp:101043512228 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217380: rtcpu_nvcsi_intr: tstamp:101043512778 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/4:1-4007 [004] .... 3210.217381: rtcpu_nvcsi_intr: tstamp:101043512778 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
