I am new to GPU programming. Before I start using CUDA, I want to know if the following is possible:
Transforming a large vertex array by a rotation matrix using CUDA.
Fast 2D sorting using CUDA.
Fast triangle rasterization on GPU using CUDA. (Scanline rendering in memory)
Should return a buffer containing 1 for triangle pixel. -
Has anyone wrote a Type Library to be used with “VB6”. This would be really of great help to VB programmers to harness the power of GPU computing in a simplest way.
Any relevant links, source code examples are most welcome.
Thanks in advance.
Keep smiling,
mahesh.
